I wonder is there anyway to save the depth in 16bits image (PNG) instead of 8bits.
In systheticdata_recoder.py
, there are lines doing as follows. But the input data is already 8bit.
def save_image(self, img_type, image_data, filename):
if img_type == "RGB":
# Save ground truth data locally as png
rgb_img = Image.fromarray(image_data, "RGBA")
rgb_img.save(f"{self.rgb_folder}/{filename}.png")
elif img_type == "DEPTH":
# Convert linear depth to inverse depth for better visualization
image_data = image_data * 100
image_data = np.reciprocal(image_data)
image_data[image_data == 0.0] = 1e-5
image_data = np.clip(image_data, 0, 255)
image_data -= np.min(image_data)
image_data /= np.max(image_data)
depth_img = Image.fromarray((image_data * 255.0).astype(np.uint8))
depth_img.save(f"{self.depth_folder}/{filename}.png")
