I have installed jetpack 4.2.2(headless mode) and then manually installed the libraries i need for my program such as jupyter, matplotlib,dlib,numpy ,keras ,tensorflow-gpu(1.14) and so on. It took multiple hours to install all libraries. I am worried if something goes wrong i might have to start all the way from scratch, is there way to save the sdcard image to a file and when required use “etcher” to burn the image to have all the options i have, something similar to having a restore point in windows.
Hi surajkandukuri,
Since Jetson-Nano working with SD card to allocate partitions,
suggest you should refer to similar discussion threads, such as Topic 1050990, and Topic 1052633 for the steps to clone SD-cards.
