Hi! I am having some issues installing Jetpack 4.6.1 in a Xavier AGX running on a custom carrier board.
I want to save the sdk logs to debug the install.
The command i am using is:
docker run -it --rm --privileged -v /dev/bus/usb:/dev/bus/usb/ --volume /tmp/:/home/nvidia/nvidia:rw --name JetPack_TX2_Devkit sdkmanager --cli install --logintype devzone --product Jetson --target P2888-0001 --targetos Linux --version 4.6.1 --select 'Jetson OS' --deselect 'Jetson SDK Components' --flash all --license accept --staylogin true --datacollection disable --exitonfinish
