Save the picture data of the first few frames of the tracking object
• Hardware Platform (Jetson)
**• DeepStream Version6.x
• JetPack Version (4.6
**• TensorRT Version8.x
Hello:
I successfully ran example deepstream-test2 and enabled the tracker.According to the code, I can get the position coordinates of the tracking object in the past period of time, but I don’t know how to use the position coordinates to save the corresponding picture data.
You can refer to thedeepstream-imagedata-multistream-redaction.
Sorry, I’ve seen the source code of the example you gave. I can only save the picture data at the current time. What I want to save is the picture information of the first few frames after the tracking target disappears from the visual area
What do you mean by
If it’s a certain area, maybe you can usenvanalytics.
And I didn’t get your point. If you want to save the frames once one tracked object disappears, just add a simple logic? For example, you can get all tracked id in one frame, compare them with previous.
I want to keep the historical frame after the tracking object disappears
Ok, that’s a question. Sorry I don’t know either.
There is no place to store the previous frames. Yo may need to store and crop the historical frames in your app.
