Saved video clips duration below 25 sec are not playing in browser
• Hardware Platform (Jetson / GPU) - Jetson Nano
• DeepStream Version - 6.0.1
• JetPack Version (valid for Jetson only) 4.6.3
• TensorRT Version - 8.2
• NVIDIA GPU Driver Version (valid for GPU only) - 10.2
I am using DeepStream to capture video clips from RTSP streams and storing them using the ‘splitmuxsink’ element with Matroska container format. Afterward, I upload these video clips to DigitalOcean’s cloud storage using the Boto3 library. When the video duration exceeds 25 seconds, they can be played directly in a web browser. However, videos with a duration below 25 seconds do not play as expected.
create a pipeline to store rtsp stream with 30 seconds interval using splitmuxsink ‘split-now’. Then upload to any cloud space.
could you help me to resolve this issue?
Could you attach us the videos below 25 sec and up 25 sec? This looks more like a web limitation issue. Which browser are you using, google , Edge or others?
Not playing:
  1. https://sgp1.digitaloceanspaces.com/tentovision/Device_Demo/2023-10-27/A2/10:11:37.mp4
  2. https://sgp1.digitaloceanspaces.com/tentovision/Device_Demo/2023-10-27/A8/10:12:28.mp4
  3. https://sgp1.digitaloceanspaces.com/tentovision/Device_Demo/2023-10-27/A9/10:13:59.mp4
Playing:
  1. https://sgp1.digitaloceanspaces.com/tentovision/Device_Demo/2023-10-27/A8/10:15:09.mp4
  2. https://sgp1.digitaloceanspaces.com/tentovision/Device_Demo/2023-10-27/A8/10:14:22.mp4
The graph you attached is unclear. So could you attach a clear picture and the whole config file? You may set some parameters like I frame intervals for your encoder and try.
pipeline.zip (4.3 MB)
OK. Could you try to set the iframeinterval parameter in the config file and have a try?
