I want to generate and save a map in Isaac Perceptor because the necessary packages for that (nvBlox, VSlam, and DNN) are included in it.
The problem is that the map gets cleared after a period of time. In the nvblox package, you can change the parameter decay_tsdf_rate_hz
to 0.0 to prevent this issue. However, in the Perceptor package, I only found a file called “nvblox_perceptor.yaml”, and this file does not contain the decay_tsdf_rate_hz
parameter.
What can I do to retain the points in the 3D environment?
Hi @maltedaniel.lueder, and welcome to the Isaac ROS forum.
You can modify the file nvblox_perceptor.yaml
by adding decay_tsdf_rate_hz
and/or other parameters if you need. The nvblox node will load all parameters.
Let me know if I helped you.
Best,
Raffaello
Hey @Raffaello
thank you for the information.
It works with the NvbloxMesh Topic, but not with the “back_projected_depth” topic.
Is there a parameter, that the pointcloud is not cleared after a period of time?
