Saving Metadata
How to save metadata using Deepstream over t4 based workstation
Can you check the samples test1, test2?
osd_sink_pad_buffer_probe will extract metadata received on OSD sink pad and update params for drawing rectangle, object information etc.
I ran test1 and test2. How to save those metadata in text files
Change the code. Or try to set [application] config “gie-kitti-output-dir”
What required to change? sink option or new functions is needed??
Hi qweasdzxc,
Have you manaaged to save the metadata into a text file?
Any result can be shared?
