Sbsar Extension in simulation script
Hey all! Similiar question to Sequencer Extension in sim script
I am trying to use sbsar extension with SimulationApp(). I should autoload that because that doesn’t work when enabling at runtime.
So I decided to add it to Config and load that while creating SimulationApp() like;
GEN_CONFIG = {
            "extensions": {
                "console": {
                    "filterLevel": -1,
                    "sources": {
                        "usd.fileformat.sbsar": True,
            "exts": {
                "enabled": [
                    "omni.kit.property.sbsar-0.8.0"
        "renderer": out_config["rendertype"],
        # "renderer": "PathTracing",
        "headless": False,
    from omni.isaac.kit import SimulationApp
    simulation_app = SimulationApp(GEN_CONFIG)
However this isn’t works too. How should I prepare the config to make that work ?
-Update-
I figured out how to enable SBSAR ext however I should enable usd.fileformat.sbsar extension too
    import omni.kit.app
    manager = omni.kit.app.get_app().get_extension_manager()
    manager.set_extension_enabled_immediate("omni.kit.property.sbsar-0.8.0", True)
    manager.set_extension_enabled_immediate("usd.fileformat.sbsar", True)
Throws:
Can't find extension with name: usd.fileformat.sbsar
That because its a non-toggleable extension normally. How can I solve that issue ?
Hi @berkayeraydin
If you want the extension to be enabled for standalone applications, you can edit the omni.isaac.sim.python.kit file (in <path_to_isaac_sim>/apps folder) and uncomment the related extensions in line 229
# SBSAR
"omni.kit.property.sbsar" = {}
"omni.usd.fileformat.sbsar" = {}
or run the script with the following arguments:
./python.sh script.py --enable omni.kit.property.sbsar --enable omni.usd.fileformat.sbsar
Hi @berkayeraydin
The name of the second extension is omni.usd.fileformat.sbsar (at least in Isaac Sim 2022.2.0)
import omni.kit.app
manager.set_extension_enabled_immediate("omni.kit.property.sbsar", True)
manager.set_extension_enabled_immediate("omni.usd.fileformat.sbsar", True)
