SC7休眠後 不明原因自動離開SC7模式 …導致後續按下power Key 離開休眠模式時…會甦醒失敗
但有時又正常 不會自動離開SC7模式,按下power Key 離開休眠模式…可正常甦醒
root@Jetson:/home/nvidia# [ 620.547434] Trying to unregister non-registered hwtime source
?歊lk_mach_suspend_early
clk_mach_suspend_early done
suspended vdd_core @ 950000uV
跴pe entering sc7
歊lk_mach_suspend
clk_mach_suspend done
fmon_suspend done
t234_adc_suspend done
WAKE_MASK[31:0] = 0x21000100
WAKE_MASK[63:32] = 0x0
WAKE_MASK[95:64] = 0x1ff200
TIER0[31:0] = 0x0
TIER0[63:32] = 0x0
TIER0[95:64] = 0x0
TIER1[31:0] = 0x0
TIER1[63:32] = 0x0
TIER1[95:64] = 0x0
TIER2[31:0] = 0x21000100
TIER2[63:32] = 0x0
TIER2[95:64] = 0xff200
[0649.295] I> MB1 (version: 1.2.0.0-t234-54845784-9613e64d)
[0649.301] I> t234-A01-0-Silicon (0x12347) Prod
[0649.307] I> Boot-mode : SC7 Exit
[0649.311] I> Entry timestamp: 0x00000000
[0649.316] I> last_boot_error: 0x0
[0649.320] I> BR-BCT: preprod_dev_sign: 0
[0649.325] I> rst_source: 0xc, rst_level: 0x3
[0649.330] I> Task: SE error check
[0649.334] I> Task: Enable SLCG
[0649.338] I> Task: CRC check
[0649.341] I> Skip FUSE records CRC check as records_integrity fuse is not burned
[0649.350] I> Task: Crypto init
[0649.354] I> Task: NVRNG health check
[0649.358] I> NVRNG: Health check success
[0649.363] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0649.370] I> Task: Verify SDRAM params
[0649.376] I> Task: MSS Encrypt status check
[0649.381] I> Task: NV_SC7 integrity check
[0649.390] I> Task: Initialize SOC Therm
[0649.395] I> Task: Program NV master stream id
[0649.400] I> Task: Verify boot mode
[0649.407] I> Task: Alias fuses
[0649.412] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0649.420] I> Task: Print SKU type
[0649.424] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000038
[0649.430] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0649.436] I> FUSE_OPT_TPC_DISABLE = 0x00000002
[0649.441] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0649.446] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0649.452] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0649.457] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0649.462] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[0649.468] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0649.473] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0649.478] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0649.483] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0649.488] I> FUSE_SKU_INFO_0 = 0xd2
[0649.493] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0649.498] I> FUSE_PACKAGE_INFO_0 = 0x2
[0649.502] I> SKU: Prod
[0649.506] I> Task: Boost clocks
[0649.509] I> Initializing PLLC2 for AXI_CBB.
[0649.515] I> AXI_CBB : src = 35, divisor = 0
[0649.520] I> Task: Voltage monitor
[0649.524] I> VMON: Vmon re-calibration and fine tuning done
[0649.531] I> Task: TSC init
[0649.535] I> Task: Thermal check
[0649.539] I> max_chip_limit = 105
[0649.543] I> min_chip_limit = -28
[0649.547] I> max temp read = 32
[0649.551] I> min temp read = 31
[0649.555] I> Task: Update FSI SCR with thermal fuse data
[0649.561] I> Task: Enable WDT 5th expiry
[0649.566] I> Task: I2C register
[0649.570] I> Task: Set I2C bus freq
[0649.574] I> Task: Reset FSI
[0649.578] I> Task: Pinmux init
[0649.589] I> Task: Prod config init
[0649.594] I> Task: Pad voltage init
[0649.598] I> Task: Prod init
[0649.602] I> Task: Common rail init
[0649.607] I> DONE: Thermal config
[0649.613] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0649.623] I> DONE: SOC rail config
[0649.629] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0649.636] I> DONE: MEMIO rail config
[0649.641] I> DONE: GPU rail info
[0649.645] I> DONE: CV rail info
[0649.649] I> Task: Misc. board config
[0649.654] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0649.661] I> Task: Enable clock-mon
[0649.677] I> FMON: Fmon re-programming done
[0649.682] I> Task: CCPLEX IST init
[0649.687] I> Task: CPU WP0
[0649.691] I> Loading MCE
[0649.708] I> Sending WP0 mailbox command to PSC
[0649.718] I> Task: MB1 fixed firewalls
[0649.744] I> Task: BPMP fw ast config
[0649.748] I> Task: Load nvdec-fw
[0649.766] I> Task: Program TSEC carveout
[0649.770] I> TSEC-FW load not enabled
[0649.775] I> Task: GPIO interrupt map
[0649.780] I> Task: Unpowergate AOPG CAN
[0649.785] I> Task: Misc NV security settings
[0649.790] I> NVDEC sticky bits programming done
[0649.795] I> Successfully powergated NVDEC
[0649.800] I> Task: Disable/Reload WDT
[0649.805] I> Task: Program BPMP-IPC carveouts
[0649.810] I> Program IPC carveouts
[0649.816] I> SLCG Global override status := 0x0
[0649.821] I> MB1: MSS reconfig completed
[0649.830] I> Program carveout CARVEOUT_TEMP_MB2RF before image load
I> MB2 (version: 0.0.0.0-t234-54845784-a822a8cb)
I> Emulation:
I> Entry timestamp: 0x26bc32fd
I> Regular heap: [base:0x40040000, size:0x2000]
I> Task: ARI update carveout TZDRAM (0x40053cb0)
I> Task: Enable hot-plug capability (0x400609fc)
I> Task: PSC mailbox init (0x400588b4)
I> Task: Crypto init (0x40055a78)
I> Task: Enable GP-SE clock (0x40053db8)
I> Task: OEM SC7 context integrity check (0x400598bc)
I> Task: Restore FSI padctl config (0x400590ac)
I> Task: Program CBB PCIE AMAP regions (0x40059bc4)
I> Task: Load and authenticate registered FWs (0x4005b550)
I> Task: Load AUXP FWs (0x4006059c)
I> Skipping SCE FW load
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x82d700000
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x836000000
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x82e400000
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x82db00000
I> Task: Carveout setup (0x4005d8d0)
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM (0x4005864c)
I> Task: Enable FSI VMON (0x40058148)
I> FSI VMON: FSI Vmon re-calibration and fine tuning done
I> Task: Validate FSI Therm readings (0x4005822c)
I> FSITHERM max temp = 32
I> FSITHERM min temp = 31
I> Task: Enable FSI SE clock (0x40058c54)
I> Enable FSI-SE clock and 10ms delay...
I> Task: Initialize SBSA UART CAR (0x40053d1c)
I> Task: Unpowergate APE (0x400594a4)
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: OEM firewalls (0x4005fb78)
I> OEM firewalls configured
I> Task: Powergate APE (0x40059618)
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings (0x4006001c)
I> Task: Deinit UART (0x40053bfc)
Reset reason 0x33
t234_adc_resume done
clk_mach_resume
clk_mach_resume done
跴pe exiting sc7
歊lk_mach_resume_late
I> Task: Start secure NOR provision (0x400599dc)
I> Task: Load FSI keyblob (0x40058c9c)
I> Skipping FSI key blob copy
I> Task: Unhalt AUXPs (0x4006080c)
I> SCE unhalt skipped
I> Unhalting RCE
I> RCE unhalt successful
I> DCE unhalt successful
I> APE unhalt skipped
I> FSI unhalt skipped
I> Task: Load CPUBL (0x4嬂 649.970870] Camera-FW on t234-rce-safe started
TCU early console enabled.
?0597bc)
I> Task: Load TOS (0x400597e0)歊lk_mach_resume_late done
I> Task: Disable MSS perf stats (0x40060898)
I> Task: Program display sticky bits (0x40060814)
I> Task: SMMU external bypass disable (0x40058898)
I> Task: SMMU init (0x40058678)
I> Task: Program GICv3 registers (0x40060938)
I> Task: Audit firewall settings (0x4005fdd8)
I> MB2 finished榹TATUS_R[31:0] = 0x1000100
STATUS_R[63:32] = 0x0
STATUS_R[95:64] = 0x100000
誏OTICE: tegra_soc_pwr_domain_on_finish: exited SC7 successfully. Entering normal world.
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 8 initializing
I/TC: Secondary CPU 8 switching to normal world boot
I/TC: Secondary CPU 9 initializing
I/TC: Secondary CPU 9 switching to normal world boot
I/TC: Secondary C嬂 650.183642] Camera-FW on t234-rce-safe ready SHA1=8676d22a (crt 2.938 ms, total boot 215.915 ms)
谽U 10 initializing
I/TC: Secondary CPU 10 switching to normal world boot
I/TC: Secondary CPU 11 initializing
? FW Boot DoneCPU 11 switching to normal world boot踜CE?
請問有任何建議嗎??
