I try ton run the following program
PROGRAM test_mat
implicit none
integer, parameter :: wp = selected_real_kind(13,99)
INTEGER :: INCON
INTEGER :: I,J,INFO
INTEGER :: DESCA(9)
real(wp) :: RCOND
complex(wp) , pointer :: Z(:)
integer , pointer :: IPIV(:)
integer stat, offset,iam,nprocs, ictxt,numroc
integer NPROW, NPCOL, MYROW, MYCOL,np, nq,pb
! Taille du systeme
INCON = 12629
NPROCS=0
! Get starting information
CALL BLACS_PINFO( IAM, NPROCS )
IF (NPROCS.eq.1) then
write(,)‘nprocs = ‘,NPROCS
ENDIF
! Define process grid
CALL BLACS_GET( 0, 0, ICTXT )
NPROW=1
NPCOL=1
CALL BLACS_GRIDINIT( ICTXT, ‘R’, NPROW, NPCOL )
CALL BLACS_GRIDINFO( ICTXT, NPROW, NPCOL, MYROW, MYCOL )
PB=173
NP=NUMROC(INCON,PB,MYROW,0,NPROW)
NQ=NUMROC(INCON,PB,MYCOL,0,NPCOL)
DESCA(1)=1
DESCA(2)=ICTXT
DESCA(3)=INCON
DESCA(4)=INCON
DESCA(5)=PB
DESCA(6)=PB
DESCA(7)=0
DESCA(8)=0
DESCA(9)=INCON
WRITE(,‘(A,3(2x,I6))’) ’ Number of unknowns:',INCON
! allocations
allocate (Z(inconincon),STAT=stat)
print*,‘size z’,SIZE(Z)
do i=1,incon
do j=1,incon
offset = (i-1) * incon + j
Z(offset) = CMPLX(0.0_wp,0.0_wp)
if (i.eq.j) Z(offset) = CMPLX(2.0_wp,0.0_wp)
enddo
enddo
allocate (IPIV(incon),STAT=stat)
write(,) ‘lecture terminee, appel a pzgetrf()’
CALL PZGETRF(INCON,INCON,Z,1,1,DESCA,IPIV,INFO)
write(,) ‘fin appel a pzgetrf()’
IF(INFO.NE.0) THEN
WRITE(,) ’ PROBLEM in PZGETRF INFO=’,INFO
WRITE(,) ’ See Scalapack Documentation’
stop ’ stop in p_resol’
ELSE
WRITE(,) ‘ZGETRF is ok’
END IF
RETURN
END
using PGI CDK 64 bits environnement v6.2. (Linux kernel 2.6.9-22ELsmp)
Compilation is ok but execution has problem…
I have a MPI error like “wrong communicator…”
Could you please help me?
Thank’s
John
