Scattering uniqe instances
i have a directory with 6 different usds. I use the following function to scatter 2 usd ata time on a plane in the stage:
def randomize_tool(directory, area, rotate = False, _size = 2):
        tools = rep.utils.get_usd_files(directory)
        traversable_plane = rep.get.prim_at_path(area)
        with rep.randomizer.instantiate(tools, size=_size, use_cache = False):
            rep.randomizer.scatter_2d(traversable_plane, check_for_collisions=True)
            if rotate:
                rep.modify.pose(rotation =rep.distribution.uniform((0,0,0), (0,0,180)))
now the issue is, that sometimes, twice of the same usd is instantiated. how do i limit the scatter function to select uniqe usds?
thank you
Hi there,
you can try using the with_replacement argument with False.
Here is its description:
When ``False``, avoids duplicates when sampling. Default ``True``. NOTE: if the paths is a ReplicatorItem, with_replacements will be ignored.
awesome, thank you.
