ScatterND op output mismatched with ONNX
Description
I am doing a model deployment, things going fine with TensorRT 8.0.1, CUDA 11.3 and ONNX model exported with opset=11. but recently I tried to upgrade to TensorRT 8.5.1.7, CUDA 11.8 and export the ONNX model with opset=16, the efficiency improves a lot. However, the TRT model always give the wrong result.
So I compare the output layer by layer using the Polygraphy tool, and the report says the outputs of ScatterND ops mismatched with the output from ONNX.
The wired thing is that if I just compare the last output by running the command below, the comparision will not pass.
POLYGRAPHY_AUTOINSTALL_DEPS=1 \
polygraphy run model.onnx \
    --onnxrt --trt \
    --save-engine=model.plan \
    --atol 1e-4 --rtol 1e-4 \
    --verbose \
    > result-run-FP32.txt 2>&1
but if I mark all layers as output and compare all layers outputs, the comparision with just pass on the last output, with a few layers failed.
    --onnxrt --trt \
    --save-engine=model_markall.plan \
    --verbose \
    --onnx-outputs mark all \
    --trt-outputs mark all \
    > result-run-FP32-markall.txt 2>&1
So I tried to avoid to mark all layers as output, I mark some key layers as output, and finally find the layers give the wrong output, and they happens all to be ScatterND ops.
Here’s my command
polygraphy run model.sim.onnx \
    --onnxrt --trt \
    --save-engine=model_sim_markmiddle.plan \
    --atol 1e-3 --rtol 1e-3 \
    --verbose \
    --onnx-outputs \
        '/Reshape_12_output_0' \
        '/reg_x_layer.0/layer/layer.0/Gemm_output_0' \
        '/reg_x_layer.0/layer/layer.1/Clip_output_0' \
        '/reg_x_layer.0/layer/layer.2/Gemm_output_0' \
        '/reg_x_layer.0/layer/layer.3/Clip_output_0' \
        '/reg_x_layer.0/layer/layer.4/Gemm_output_0' \
        '/reg_z_layer.0/layer/layer.0/Gemm_output_0' \
        '/reg_z_layer.0/layer/layer.1/Clip_output_0' \
        '/reg_z_layer.0/layer/layer.2/Gemm_output_0' \
        '/reg_z_layer.0/layer/layer.3/Clip_output_0' \
        '/reg_z_layer.0/layer/layer.4/Gemm_output_0' \
        '/reg_vis_layer.0/layer/layer.0/Gemm_output_0' \
        '/reg_vis_layer.0/layer/layer.1/Clip_output_0' \
        '/reg_vis_layer.0/layer/layer.2/Gemm_output_0' \
        '/reg_vis_layer.0/layer/layer.3/Clip_output_0' \
        '/reg_vis_layer.0/layer/layer.4/Gemm_output_0' \
        '/cls_layer.0/layer/layer.0/Gemm_output_0' \
        '/cls_layer.0/layer/layer.1/Clip_output_0' \
        '/cls_layer.0/layer/layer.2/Gemm_output_0' \
        '/cls_layer.0/layer/layer.3/Clip_output_0' \
        '/cls_layer.0/layer/layer.4/Gemm_output_0' \
        '/Reshape_13_output_0' \
        '/Reshape_16_output_0' \
        '/Add_24_output_0' \
        '/ScatterND_2_output_0' \
        '/ScatterND_3_output_0' \
        '/ScatterND_4_output_0' \
        '/ScatterND_5_output_0' \
        '/ScatterND_6_output_0' \
        '2442' \
    --trt-outputs \
        '2442' \
    --plugins='/usr/local/TensorRT/lib/libnvinfer_plugin.so' \
    > result-run-FP32-markmiddle.txt 2>&1
The model graph loos like
and Polygraphy generate report as
result-run-FP32-markmiddle_op_xzviscls_r1316_add24_scatterND23456_p.txt (141.1 KB)
Also, I tried to upgrade the TensorRT to 8.6.1.6, and re-export the ONNX model with opset=17, the TRT model still gives the wrong results.
How can I fix this issue and get the right output?
Environment
TensorRT Version: 8.5.1.7
GPU Type: NVIDIA GeForce GTX 1050 Ti
Nvidia Driver Version: 535.54.03
CUDA Version: 11.8
CUDNN Version: 8.9.0
Operating System + Version: Host: Ubuntu 16.04.7 LTS, Docker Container: Ubuntu 20.04.6 LTS
Python Version (if applicable): python3.8
PyTorch Version (if applicable): 2.1.0a0+fe05266
Container: nvidia/cuda:11.8.0-cudnn8-devel-ubuntu20.04
Relevant Files
ONNX Model: model.onnx - Google Drive
Could you please share model.sim.onnx and complete verbose logs on the latest TensorRT version 8.6.1 for better debugging?
Thank you.
Sorry for late reply,
the complete onnx model file can be accessed at
the detailed logs from trtexec and polygraphy are attached
trtexec
trtexec_result_2023-11-20_02-53-24.log (2.1 MB)
polygraphy
polygraphy_result_onnxrt_trt_2023-11-20_03-13-28.log (10.2 KB)
polygraphy_result_onnxrt_trt_2023-11-20_03-18-35.log (1.7 MB)
In the first Polygraphy log, it appears that the TRT model has mismatched results on the final output layers. The second Polygraphy log indicates that the output of all layers matches when all layers are marked as output layers.
Following the how-to guide on debugging accuracy, I have reduced a minimal failing case, and you can access it at
Thank you for your assistance, and I look forward to your reply!
