Hi NVIDIA team,
We encountered a reproducible-looking Argus/SCF synchronization stall while continuously capturing from two hardware-synchronized GMSL cameras in a single LibArgus CaptureSession.
Platform information:
- Jetson AGX Orin-based platform
- Jetson Linux R35.6.0
- JetPack 5.1.5
- Kernel: 5.10.216-tegra
- NVIDIA Libargus Camera Service: 0.99.33
- nvidia-l4t-camera/core/multimedia: 35.6.0
- Two S56 GMSL cameras
- Resolution: 1280x960
- Frame rate: 30 fps
- Both cameras are captured continuously by one custom LibArgus application
- Hardware frame synchronization is enabled
The application started capturing at approximately 13:47:10 and ran normally for about 3 hours 28 minutes. At 17:15:41, nvargus-daemon reported:
2026-09-07T17:15:41.747171+08:00 SCF: Error Timeout:
(propagating from src/components/amr/Snapshot.cpp,
function waitForNewerSample(), line 91)
2026-09-07T17:15:41.747304+08:00
SCF_AutocontrolACSync failed to wait for an earlier frame to complete.
2026-09-07T17:15:41.747352+08:00 SCF: Error Timeout:
(propagating from src/components/ac_stages/ACSynchronizeStage.cpp,
function doHandleRequest(), line 126)
2026-09-07T17:15:41.747383+08:00 SCF: Error Timeout:
(propagating from src/components/stages/OrderedStage.cpp,
function doExecute(), line 137)
2026-09-07T17:15:41.747405+08:00
SCF: Error Timeout: Sending critical error event for Session 0
About five seconds later, several capture requests remained pending and
waitForIdle() timed out. Additional timeouts then occurred in
CaptureContainerImpl::assignAllBuffersFromStream and CCDataSetupStage.
When the client was eventually terminated, Argus reported an outstanding
request, queue and session, followed by:
- Cleaning up 2 outstanding streams
- 5 buffers still pending during EGLStreamProducer destruction
The daemon/application could not recover cleanly and later had to be
terminated during service shutdown.
Kernel log observations:
- No NVCSI/VI CRC errors
- No CHANSEL_NOMATCH
- No missing SOF/EOF or waitCsiFrameStart/waitCsiFrameEnd errors
- No sensor or SerDes link-loss message
- No FuSa capture error
This looks similar to the following synchronized stereo camera issue on
JetPack 6.2.2:
Could NVIDIA please advise:
Is this a known SCF AutoControl synchronization issue when multiple
hardware-synchronized cameras share one CaptureSession? -
Does enableCamInfiniteTimeout affect
Snapshot::waitForNewerSample()/ACSynchronizeStage, or is it only useful
for sensor/VI frame timeouts? -
Are matched engineering versions of libnvargus, libnvscf,
libnvfusacap and the camera firmware required for an existing fix on
R35.6.0? -
Is moving the two cameras into separate CaptureSessions the recommended
workaround? If so, can hardware synchronization still be preserved? -
Which Argus tracing/debug options can identify the camera or metadata
frame whose AutoControl snapshot stopped advancing? -
What is the recommended EVENT_TYPE_ERROR recovery sequence? In this
case, waitForIdle() and EGLStream cleanup also stalled, so restarting
only the capture requests did not appear sufficient.
We can provide the complete sanitized nvargus-daemon and kernel logs if
required.
