SCF: Error InvalidState
I have a problem when I use Argus. I get the following error message, which spams the console. And makes it almost impossible to analyse.
SCF: Error InvalidState: Session has suffered a critical failure (in src/api/Session.cpp, function capture(), line 734)
(Argus) Error InvalidState:  (propagating from src/api/ScfCaptureThread.cpp, function run(), line 110)
Does anyone have any idea what the problem could be?
I was able to capture als some more information:
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
---- imager: Found override file [/var/nvidia/nvcam/settings/imx888_0_part.isp]. ----
CAM: serial no file already exists, skips storing again---- imager: Found override file [/var/nvidia/nvcam/settings/imx888_1_part.isp]. ----
CAM: serial no file already exists, skips storing againSCF: Error BadValue: NvPHSSendThroughputHints (in src/common/CameraPowerHint.cpp, function sendCameraPowerHint(), line 56)
CAM: serial no file already exists, skips storing againInitializing CUDA
PowerServiceCore:handleRequests: timePassed = 2193
PowerServiceCore:handleRequests: timePassed = 2700
PowerServiceCore:handleRequests: timePassed = 2188
SCF: Error Timeout: Sending critical error event for Session 2
 (in src/api/Session.cpp, function sendErrorEvent(), line 1039)
PowerServiceCore:handleRequests: timePassed = 2711
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 2, capture sequence ID = 3 draining session frameStart events 1
 (in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 532)
SCF: Error InvalidState: Sensor 2 already in same state
 (in src/services/capture/CaptureServiceDeviceSensor.cpp, function setErrorState(), line 100)
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 2, capture sequence ID = 2 draining session frameEnd events 2
 (in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 635)
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 2, capture sequence ID = 3 draining session frameEnd events 1
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 2, capture sequence ID = 4 draining session frameStart events 1
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 2, capture sequence ID = 4 draining session frameEnd events 1
SCF: Error BadParameter: CC has already been disposed (in src/components/CaptureContainerManager.cpp, function dispose(), line 161)
The message tell can’t get frame data and timeout.
Do you confirm the sensor driver by v4l2-ctl --stream-mmap?
The message does not appear all the time only sometimes.
Some futher information:
  • Jetson Orin NX
  • Jetpack 5.1.2-b104
Reboot the system and run below command. Then start to run the camera to check the problem.
sudo su
echo on > /sys/devices/platform/*rtcpu/power/control
