The platform I am using is TX1 R28.2. I am debugging the camera. The application refers to the example 10_camera_recording. I need the camera to run simultaneously with a CSI device (device A).
At present, device A and the camera can be operated simultaneously and are relatively stable. But when I keep restarting device A, there will be an error in the camera section, printed as follows:
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
launchCC abort cc 15190 session 0
SCF: Error Timeout: (propagating from src/api/Session.cpp, function capture(), line 830)
(Argus) Error Timeout: (propagating from src/api/ScfCaptureThread.cpp, function run(), line 109)
(Argus) Error InvalidState: MetadataResult callback for unknown capture. (in src/api/CaptureSessionImpl.cpp, function metadataResult(), line 705)
launchCC abort cc 15191 session 0
launchCC abort cc 15192 session 0
launchCC abort cc 15193 session 0
launchCC abort cc 15194 session 0
launchCC abort cc 15195 session 0
launchCC abort cc 15196 session 0
launchCC abort cc 15197 session 0
launchCC abort cc 15198 session 0
launchCC abort cc 15199 session 0
launchCC abort cc 15200 session 0
launchCC abort cc 15201 session 0
launchCC abort cc 15202 session 0
launchCC abort cc 15203 session 0
launchCC abort cc 15204 session 0
I didn’t find any information that can locate the problem. I don’t have a good debugging idea yet. I need your help.
Thank you.
