In my application, which ran successfully on Jetpack 3.0, I create several threads and set them to use SCHED_FIFO. I then use the MMApi/Argus to capture and encode video from the onboard camera on a TX2 developer kit. The same application would not run once I updated to Jetpack 3.1, and I finally narrowed it down to the usage of SCHED_FIFO.
The problem is that calling ICaptureSession::createOutputStream will hang for a while, during which a lot of error messages are printed on the console. After all the logs are done printing, the device will reboot eventually.
Once I discovered the root cause, I modified the 10_camera_recording MMApi sample to set the main thread to SCHED_FIFO, and this allows me to reproduce the problem with the sample app. Below is a patch that you should be able to apply to the sample if you want to reproduce it. You will have to run the program as root in order for the SCHED_FIFO mode to take effect of course.
--- //main_original.cpp Fri Dec 1 11:36:28 2017
+++ //main_hang.cpp Fri Dec 1 11:30:11 2017
@@ -44,0 +45,3 @@
+#include <sys/time.h>
+#include <sys/resource.h>
@@ -549,0 +553,7 @@ int main(int argc, char *argv[])
+ // WARNING This code will cause problems!
+ printf( "Setting SCHED_FIFO\n" );
+ struct sched_param scheduleParams;
+ scheduleParams.sched_priority = 90;
+ pthread_setschedparam( pthread_self(), SCHED_FIFO, &scheduleParams );
Now run the sample:
sudo ./camera_recording -d 5
Here is a short snippet of the resulting logs. Note that the above patch added the printout “Setting SCHED_FIFO” which appears at the beginning of the log.
nvidia@tegra-ubuntu:~/workdir$ sudo ./camera_recording -d 5
Set governor to performance before enabling profiler
Setting SCHED_FIFO
PCLHW_DTParser
PCLHW_DTParser
LoadOverridesFile: looking for override file [/Calib/camera_override.isp] 1/16LoadOverridesFile: looking for override file [/data/nvcam/settings/camera_overrides.isp] 2/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/camera_overrides.isp] 3/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/camera_overrides.isp] 4/16LoadOverridesFile: looking for override file [/data/nvcam/camera_overrides.isp] 5/16LoadOverridesFile: looking for override file [/data/nvcam/settings/e3326_front_P5V27C.isp] 6/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/e3326_front_P5V27C.isp] 7/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/e3326_front_P5V27C.isp] 8/16---- imager: No override file found. ----
PRODUCER: Creating output stream
[ 837.334986] host1x 13e10000.host1x: AoltmStage: syncpoint id 47 (17000000.gp10b_493) stuck waiting 2, timeout=-1
[ 837.345153] ---- syncpts ----
[ 837.348133] id 4 (disp_d) min 121 max 121 refs 1 (previous client : )
[ 837.354566] id 5 (disp_e) min 1 max 1 refs 1 (previous client : )
[ 837.360654] id 7 (vblank1) min 50073 max 0 refs 1 (previous client : )
[ 837.367186] id 18 (17000000.gp10b_507) min 6866 max 6866 refs 1 (previous client : )
[ 837.374920] id 19 (17000000.gp10b_506) min 22 max 22 refs 1 (previous client : )
[ 837.382308] id 20 (17000000.gp10b_505) min 650 max 650 refs 1 (previous client : 17000000.gp10b_505)
[ 837.391441] id 33 (17000000.gp10b_500) min 4 max 4 refs 1 (previous client : 17000000.gp10b_500)
[ 837.400215] id 35 (15700000.vi_0) min 14 max 14 refs 2 (previous client : 15700000.vi_0)
[ 837.408298] id 39 (150c0000.nvcsi_0) min 20 max 20 refs 2 (previous client : 150c0000.nvcsi_0)
[ 837.416906] id 46 (17000000.gp10b_494) min 2 max 4 refs 1 (previous client : 17000000.gp10b_494)
[ 837.425679] id 47 (17000000.gp10b_493) min 0 max 2 refs 1 (previous client : 17000000.gp10b_493)
[ 837.434452] id 48 (17000000.gp10b_492) min 8 max 8 refs 1 (previous client : 17000000.gp10b_492)
[ 837.443737]
[ 842.957174] gk20a 17000000.gp10b: gk20a_channel_timeout_handler: Job on channel 493 timed out
[ 842.965702] ---- mlocks ----
[ 842.968630]
[ 842.970129] ---- syncpts ----
[ 842.973110] id 4 (disp_d) min 121 max 122 refs 1 (previous client : )
[ 842.979559] id 5 (disp_e) min 1 max 1 refs 1 (previous client : )
[ 842.985651] id 7 (vblank1) min 50411 max 0 refs 1 (previous client : )
[ 842.992205] id 18 (17000000.gp10b_507) min 6866 max 6872 refs 1 (previous client : )
[ 842.999942] id 19 (17000000.gp10b_506) min 22 max 22 refs 1 (previous client : )
[ 843.442982] host1x 13e10000.host1x: AoltmStage: syncpoint id 47 (17000000.gp10b_493) stuck waiting 2, timeout=-1
[ 843.453141] ---- syncpts ----
[ 843.957088] id 20 (17000000.gp10b_505) min 650 max 656 refs 1 (previous client : 17000000.gp10b_505)
[ 843.966227] id 33 (17000000.gp10b_500) min 4 max 4 refs 1 (previous client : 17000000.gp10b_500)
[ 843.975054] id 35 (15700000.vi_0) min 14 max 14 refs 2 (previous client : 15700000.vi_0)
[ 843.983143] id 39 (150c0000.nvcsi_0) min 20 max 20 refs 2 (previous client : 150c0000.nvcsi_0)
[ 843.991768] id 46 (17000000.gp10b_494) min 2 max 4 refs 1 (previous client : 17000000.gp10b_494)
[ 844.000551] id 47 (17000000.gp10b_493) min 0 max 2 refs 1 (previous client : 17000000.gp10b_493)
[ 844.957620] id 48 (17000000.gp10b_492) min 8 max 8 refs 1 (previous client : 17000000.gp10b_492)
[ 844.966912]
[ 844.968419] ---- channels ----
[ 844.971482]
[ 844.971482] channel 1 - 15820000.se
[ 844.971482]
[ 844.977923] NvHost basic channel registers:
[ 844.982119] CMDFIFO_STAT_0: 00002040
[ 844.985781] CMDFIFO_RDATA_0: 57081332
[ 844.989456] CMDP_OFFSET_0: 00000000
[ 844.993129] CMDP_CLASS_0: 00000000
[ 844.996791] CHANNELSTAT_0: 00000000
[ 845.000457] The CDMA sync queue is empty.
[ 845.004467]
[ 845.005960]
[ 845.005960] channel 2 - 15830000.se
[ 845.005960]
[ 845.006990] id 4 (disp_d) min 121 max 122 refs 1 (previous client : )
[ 845.006993] id 5 (disp_e) min 1 max 1 refs 1 (previous client : )
[ 845.006996] id 7 (vblank1) min 50532 max 0 refs 1 (previous client : )
[ 845.007009] id 18 (17000000.gp10b_507) min 6866 max 6872 refs 1 (previous client : )
[ 845.007012] id 19 (17000000.gp10b_506) min 22 max 22 refs 1 (previous client : )
[ 845.007015] id 20 (17000000.gp10b_505) min 650 max 656 refs 1 (previous client : 17000000.gp10b_505)
[ 845.007030] id 33 (17000000.gp10b_500) min 4 max 4 refs 1 (previous client : 17000000.gp10b_500)
[ 845.007033] id 35 (15700000.vi_0) min 14 max 14 refs 2 (previous client : 15700000.vi_0)
[ 845.007039] id 39 (150c0000.nvcsi_0) min 20 max 20 refs 2 (previous client : 150c0000.nvcsi_0)
[ 845.007047] id 46 (17000000.gp10b_494) min 2 max 4 refs 1 (previous client : 17000000.gp10b_494)
[ 845.007050] id 47 (17000000.gp10b_493) min 0 max 2 refs 1 (previous client : 17000000.gp10b_493)
[ 845.007052] id 48 (17000000.gp10b_492) min 8 max 8 refs 1 (previous client : 17000000.gp10b_492)
[ 845.007561]
[ 845.982117] NvHost basic channel registers:
[ 845.986322] CMDFIFO_STAT_0: 00002040
[ 845.989996] CMDFIFO_RDATA_0: 111182f3
[ 845.993676] CMDP_OFFSET_0: 00000000
[ 845.994726] dhd_bus_rxctl: resumed on timeout, INT status=0x20C00040
[ 845.994960] dhd_bus_rxctl: rxcnt_timeout=1, rxlen=0
[ 845.994979] dhd_check_hang: Event HANG send up due to re=1 te=0 e=-110 s=2
[ 845.994986] dhd_check_hang: Event HANG send up due to re=1 te=0 e=-110 s=2
[ 845.994994] dhd_prot_ioctl : bus is down. we have nothing to do
[ 845.997350] dhd_prot_ioctl : bus is down. we have nothing to do
[ 845.997354] CFGP2P-ERROR) wl_cfgp2p_bss_isup : 'cfg bss -C 0' failed: -1
[ 845.997355] CFGP2P-ERROR) wl_cfgp2p_bss_isup : NOTE: this ioctl error is normal when the BSS has not been created yet.
[ 845.997362] dhd_prot_ioctl : bus is down. we have nothing to do
[ 845.997378] dhd_prot_ioctl : bus is down. we have nothing to do
[ 845.997381] CFG80211-ERROR) wl_dongle_down : WLC_DOWN error (-1)
[ 846.972672] CMDP_CLASS_0: 00000000
[ 846.976353] CHANNELSTAT_0: 00000000
[ 846.980030] wl_android_wifi_off in
[ 846.982980] The CDMA sync queue is empty.
[ 846.982981]
[ 846.982985]
[ 846.982985] channel 3 - 15840000.se
[ 846.982985]
[ 846.982986] NvHost basic channel registers:
[ 846.982988] CMDFIFO_STAT_0: 00002040
[ 846.982990] CMDFIFO_RDATA_0: 8c812402
[ 846.982993] CMDP_OFFSET_0: 00000000
[ 846.982995] CMDP_CLASS_0: 00000000
[ 846.982996] CHANNELSTAT_0: 00000000
[ 846.982998] The CDMA sync queue is empty.
... many more pages of logs follow until the board reboots ...
If I can provide anything else to help debug this, please let me know.
Thanks,
Chris Richardson
