Schlumberger Petrel Application Graphic Issue
Hi all,
Just wondering if anyone encountered graphic issue and if there is any solutions to this. I will attached the pictures below.
I am currently using Xenserver 6.5 and Xendesktop 7.6 with GPU Passthrough. Graphic card Grid K2.
Application is running fine but the colour of the model rendered have issues.
The model should be the similar to this
http://s4.postimg.org/4jmlvo2od/SS_OK.jpg
What we are get are pink pixels over the models where it should not happen.
http://s7.postimg.org/hafd7hki3/SS_Not_OK.jpg
Thank you
Which drivers are you using?
Also, why is it running in a small window inside the receiver window? What have you done to fix it at that resolution?
Do you get he same issue when running full screen?
