I’m going through a scratch build of the NVIDIA Jetson Xavier NX with R32.4.3 for the devkit carrier board and I noticed after I apply tegra_defconfig and in menuconfig I see that under Device Drivers → Graphics support → NVIDIA Tegra host1x driver is not selected.
Should this be enabled?
hello dlwalter,
it doesn’t need additional configuration for building kernel images.
please see-also developer guide, Debugging the Kernel on Jetson Devices .
thanks
That link seems mostly about running KGDB. Can you be more specific where on that page it says I shouldn’t need additional configuration?
Although I did find that the l4t-device-mode wasn’t working (either the usb serial or the usb ethernet).
I had to use menuconfig to enable Device Drivers → USB Support → USB Gadget Support → USB Gadget Drivers in order for that to work.
system
closed
March 9, 2022, 2:09am
#7
