nvidia-bug-report.log.gz (432.8 KB)
DESCRIPTION: After waking from sleep, my second monitor has a sporadic flicker to black under input activity.
STEPS TO REPRODUCE
1. Leave the system idle long enough for monitors to fully power down via DPMS (in this case screen off set to 10 minutes, system suspend at 15 minutes)
2. Wake the system from sleep
3. Move mouse, click, or type on either monitor
OBSERVED RESULT
Occasional flicker to black on the 2nd monitor
EXPECTED RESULT
No flickering
SOFTWARE/OS VERSIONS
Operating System: CachyOS Linux
KDE Plasma Version: 6.6.4
KDE Frameworks Version: 6.26.0
Qt Version: 6.11.0
ADDITIONAL INFORMATION
Workaround: Simply changing any display setting for either monitor will fix the isssue. I've set up a shell script to just disable and enable HDR to fix it quickly.
GPU: NVIDIA RTX 5090 (GB202) with driver 595.58.03, alongside AMD Radeon integrated graphics (Granite Ridge)
Monitors: 3440x1440 @ 164Hz (primary, DP-1) and 2560x1440 @ 144Hz (secondary, DP-3)
Issue only occurs after a full DPMS power-down cycle, not on immediate wake
I had another CachyOs install for testing on my other drive before installing it onto this current drive with the same configuration, and I did not experience this issue there.
The same monitor also has an issue around brightness, it sometimes will wake from sleep and just be a little darker
I originally submitted this to the KDE teambut was told it was likely on a lower level than KWin and to take it here.
