I just received my jetson nano today and I plugged it into a 5v4a adapter that I had laying around and it throttled saying that there’s not enough voltage (even when I set it to 5W mode). I assume that it’s due to a bad adapter.
I then changed the adapter to a 5v 2a micro usb. Everything worked fine until I plugged in a stereoscopic camera (arducam’s). The screen then started to go black for about 2 seconds in around 10 seconds interval… I thought that there’'s probably not enough power to support all peripherals (mouse, keyboard, and the camera) so I decided to unplug the camera. The screen still keep turning on and off, so I continued unplugging all peripherals and the screen still does the same thing. I tried another 5v 2a adapter… nothing’s changed.
I then switched back to the 5v 4a adapter, unfortunately the screen still flickers. Please help.
Nvidia jetson nano b01 is the version I’m using
I am using the hdmi output and the ethernet port.
I tried using the 5v 2a adapter than comes with apple’s ipad and another one from a samsung phone
Btw this happens not just when there’s load, but also in desktop when no application is running.
