I’m seeing what appears to be a DLSS integration bug in Unreal Engine 5.8 when using the NVIDIA DLSS renderer node inside Movie Render Graph.
Setup:
Unreal Engine 5.8
Movie Render Graph
Output resolution: 3840×1608
Temporal Samples: 1
Screen Percentage set to 100 before rendering
Issue:
When I set the DLSS Quality option in the Movie Render Graph node to DLAA, Movie Render Graph overrides r.ScreenPercentage to approximately 58 during the render.
The same thing happens when testing other quality selections in the MRG DLSS node. The selected mode does not appear to map correctly to the expected render percentage.
For example:
DLAA should use native resolution / 100%
In MRG it is being forced to approximately 58%
After the render completes,
r.ScreenPercentagereturns to 100%
I tested the same DLAA setup using the legacy Movie Render Queue instead of Movie Render Graph.
In legacy Movie Render Queue:
- DLAA correctly keeps
r.ScreenPercentageat 100%
So the issue appears to be specific to the Movie Render Graph DLSS node, not DLAA itself.
This makes proper DLAA image-quality comparison in MRG difficult because the render is effectively being performed at a lower internal resolution than expected.
Has anyone else reproduced this behavior in UE 5.8 with the current NVIDIA DLSS plugin?
