Screen stuck at a log
scenario 1:
ethernet is connected
board gets booted
i enterned user name and password
This is the Xorg log
scenario1.txt (12.7 KB)
I run the command
sudo systemctl restart gdm3
The monitor showed a blackscreen and restarted to he login page
I gave the username and password
I went to blackscreen
After 3…4 minutes
It came ON to login page again
After login in , device is running now
Jun  4 09:24:13 localhost compiz[9820]: /usr/bin/compiz (core) - Warn: Attempted to restack relative to 0x1a00036 which is not a child of the root window or a window compiz owns
Jun  4 09:24:13 localhost unity-panel-ser[9834]: menus_destroyed: assertion 'IS_WINDOW_MENU(wm)' failed
Jun  4 09:24:13 localhost compiz[9820]: WARN  2024-06-04 09:24:13 unity.dash.gsettingsscopereader GSettingsScopes.cpp:108 Error fetching protocol metadata for scope: social.scope : Valid key file could not be found in search dirs
Jun  4 09:24:13 localhost compiz[9820]: WARN  2024-06-04 09:24:13 unity <unknown>:0 g_settings_set_value: value for key 'visual-bell-type' in schema 'org.gnome.desktop.wm.preferences' is outside of valid range
Jun  4 09:24:13 localhost unity-panel-ser[9834]: window_menu_model_new: assertion 'BAMF_IS_APPLICATION(app)' failed
Jun  4 09:24:13 localhost unity-panel-ser[9834]: track_menus: assertion 'IS_WINDOW_MENU(menus)' failed
Jun  4 09:24:13 localhost gnome-screensav[9692]: Lost the name, shutting down.
Jun  4 09:24:13 localhost compiz[9820]: WARN  2024-06-04 09:24:13 unity <unknown>:0 Failed to fetch xid: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.ayatana.bamf.window' on object at path /org/ayatana/bamf/window/16777221
Jun  4 09:24:13 localhost compiz[9820]: WARN  2024-06-04 09:24:13 unity <unknown>:0 Failed to fetch type: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.ayatana.bamf.window' on object at path /org/ayatana/bamf/window/16777221
Jun  4 09:24:13 localhost compiz[9820]: WARN  2024-06-04 09:24:13 unity <unknown>:0 Failed to fetch monitor: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.ayatana.bamf.window' on object at path /org/ayatana/bamf/window/16777221
Jun  4 09:24:13 localhost compiz[9820]: WARN  2024-06-04 09:24:13 unity <unknown>:0 Failed to fetch maximized state: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.ayatana.bamf.window' on object at path /org/ayatana/bamf/window/16777221
Jun  4 09:24:13 localhost compiz[9820]: WARN  2024-06-04 09:24:13 unity <unknown>:0 Unable to fetch children: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.ayatana.bamf.view' on object at path /org/ayatana/bamf/application/0x559f40a1c0
Jun  4 09:24:13 localhost compiz[9820]: WARN  2024-06-04 09:24:13 unity <unknown>:0 Failed to fetch path: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.ayatana.bamf.application' on object at path /org/ayatana/bamf/application/0x559f40a1c0
Jun  4 09:24:13 localhost compiz[9820]: message repeated 7 times: [ WARN  2024-06-04 09:24:13 unity <unknown>:0 Failed to fetch path: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.ayatana.bamf.application' on object at path /org/ayatana/bamf/application/0x559f40a1c0]
Jun  4 09:24:13 localhost unity-settings-[9637]: Grab failed for some keys, another application may already have access the them.
Jun  4 09:24:13 localhost compiz[9820]: ERROR 2024-06-04 09:24:13 unity.glib.dbus.server GLibDBusServer.cpp:538 DBus name lost 'org.gnome.Shell'
Jun  4 09:24:13 localhost compiz[9820]: ERROR 2024-06-04 09:24:13 unity.glib.dbus.server GLibDBusServer.cpp:538 DBus name lost 'com.canonical.Unity'
Jun  4 09:24:13 localhost compiz[9820]: ERROR 2024-06-04 09:24:13 unity.glib.dbus.proxy GLibDBusProxy.cpp:632 Impossible to get property: Operation was cancelled
Jun  4 09:24:16 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:24:16 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:24:20 localhost compiz[9820]: WARN  2024-06-04 09:24:20 unity.filemanager.gnome GnomeFileManager.cpp:69 Locations have been invalidated, maybe there's no filemanager around...
Jun  4 09:24:24 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:24:24 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:24:28 localhost zeitgeist-daemon[7959]: #033[31m[09:24:28.985356 WARNING]#033[0m zeitgeist-daemon.vala:127: Unable to parse version info!
Jun  4 09:24:31 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:24:31 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:24:39 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:24:39 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:24:46 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:24:46 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:24:54 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:24:54 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:25:01 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:25:01 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:25:07 localhost dbus-daemon[7278]: [session uid=1000 pid=7278] Activating service name='org.freedesktop.Notifications' requested by ':1.185' (uid=1000 pid=9637 comm="/usr/lib/unity-settings-daemon/unity-settings-daem")
Jun  4 09:25:08 localhost dbus-daemon[7278]: [session uid=1000 pid=7278] Successfully activated service 'org.freedesktop.Notifications'
Jun  4 09:25:08 localhost unity-settings-[9637]: GtkDialog mapped without a transient parent. This is discouraged.
Jun  4 09:25:09 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:25:09 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:25:12 localhost gnome-software[10124]: plugin appstream took 3.3 seconds to do setup
Jun  4 09:25:12 localhost systemd[1]: Starting Snap Daemon...
Jun  4 09:25:12 localhost snapd[10147]: AppArmor status: apparmor not enabled
Jun  4 09:25:12 localhost snapd[10147]: daemon.go:347: started snapd/2.49.2+18.04 (series 16; classic; devmode) ubuntu/18.04 (arm64) linux/4.9.253-tegra.
Jun  4 09:25:12 localhost snapd[10147]: daemon.go:440: adjusting startup timeout by 30s (pessimistic estimate of 30s plus 5s per snap)
Jun  4 09:25:12 localhost systemd[1]: Started Snap Daemon.
Jun  4 09:25:12 localhost gnome-software[10124]: enabled plugins: packagekit-refine-repos, packagekit, packagekit-proxy, packagekit-local, packagekit-url-to-app, fwupd, systemd-updates, os-release, packagekit-upgrade, desktop-categories, shell-extensions, packagekit-refresh, ubuntuone, packagekit-offline, appstream, hardcoded-popular, modalias, rewrite-resource, packagekit-refine, hardcoded-featured, steam, hardcoded-blacklist, generic-updates, desktop-menu-path, odrs, provenance, packagekit-history, snap, provenance-license, icons, key-colors, key-colors-metadata
Jun  4 09:25:12 localhost gnome-software[10124]: disabled plugins: dummy, dpkg, repos, epiphany
Jun  4 09:25:13 localhost gnome-software[10124]: failed to call gs_plugin_refresh on shell-extensions: [*/*/*/source/shell-extensions/*] failed to download https://extensions.gnome.org//static/extensions.json: SSL handshake failed
Jun  4 09:25:15 localhost PackageKit: get-updates transaction /316_dcacdccd from uid 1000 finished with success after 1603ms
Jun  4 09:25:15 localhost gnome-software[10124]: failed to call gs_plugin_add_installed on shell-extensions: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.gnome.Shell.Extensions' on object at path /org/gnome/Shell
Jun  4 09:25:15 localhost gnome-software[10124]: Only 0 apps for recent list, hiding
Jun  4 09:25:16 localhost PackageKit: resolve transaction /317_ebebcbcb from uid 1000 finished with success after 950ms
Jun  4 09:25:16 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:25:16 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:25:16 localhost gnome-software[10124]: Only 8 apps for popular list, hiding
Jun  4 09:25:18 localhost PackageKit: search-file transaction /318_dbccccde from uid 1000 finished with success after 1203ms
Jun  4 09:25:19 localhost systemd[7240]: Starting Notification regarding a crash report...
Jun  4 09:25:19 localhost PackageKit: search-file transaction /319_dededaaa from uid 1000 finished with success after 1172ms
Jun  4 09:25:19 localhost update-notifier-crash[10285]: gnome-session-check-accelerated-gl-helper
Jun  4 09:25:20 localhost PackageKit: search-file transaction /320_edecdcae from uid 1000 finished with success after 1208ms
Jun  4 09:25:21 localhost PackageKit: search-file transaction /321_ecbaaaac from uid 1000 finished with success after 1150ms
Jun  4 09:25:22 localhost PackageKit: search-file transaction /322_deceecbc from uid 1000 finished with success after 1136ms
Jun  4 09:25:24 localhost PackageKit: search-file transaction /323_acdbaeca from uid 1000 finished with success after 1115ms
Jun  4 09:25:24 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
In GUI now it shows 700mb only left
scenario2 : after systemctl restart Xorg log
scenario2.txt (14.4 KB)
Jun  4 09:25:24 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:25:25 localhost PackageKit: search-file transaction /324_bedbacce from uid 1000 finished with success after 1106ms
Jun  4 09:25:25 localhost gnome-software[10124]: Failed to find one package for nvvp.desktop, /usr/share/applications/nvvp.desktop, [0]
Jun  4 09:25:26 localhost PackageKit: search-file transaction /325_bdbcdeab from uid 1000 finished with success after 1096ms
Jun  4 09:25:26 localhost gnome-software[10124]: Failed to find one package for nsight.desktop, /usr/share/applications/nsight.desktop, [0]
Jun  4 09:25:27 localhost PackageKit: search-file transaction /326_bbedcdca from uid 1000 finished with success after 1112ms
Jun  4 09:25:27 localhost snapd[10147]: daemon.go:589: gracefully waiting for running hooks
Jun  4 09:25:27 localhost snapd[10147]: daemon.go:591: done waiting for running hooks
Jun  4 09:25:27 localhost snapd[10147]: daemon stop requested to wait for socket activation
Jun  4 09:25:28 localhost PackageKit: get-details transaction /327_badcddbb from uid 1000 finished with success after 897ms
Jun  4 09:25:31 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:25:31 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:25:39 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:25:39 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:25:46 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:25:46 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:25:54 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:25:54 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:26:01 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:26:01 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:26:09 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:26:09 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:26:16 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:26:16 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:26:24 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:26:24 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:26:31 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:26:31 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:26:37 localhost NetworkManager[4143]: <info>  [1717493197.9814] connectivity: (l4tbr0) timed out
Jun  4 09:26:39 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun  4 09:26:39 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
This is the syslog
As of now the board is running
can’t identify what is the root cause
