There are multiple possible causes for an Xid 56, and unfortunately, that error message by itself isn’t enough to isolate the specific problem you are encountering.
Do you have any ideas how I can debug this issue?
I can put my GPU into another computer and check suspend/resume - will it be helpful?
I can try to find another GTX 660 to temporarily put into my PC.
There are two PCI-E x16 slots on my motherboard - should I try moving my GPU to the other (secondary) one?
I’m all ears.
BTW, this computer successfully resumes from sleep when using nouveau.
Aaron/Zander/Sandipt, any ideas?
Chiming in as I have the same issue. Started after upgrading to latest Ubuntu (13.04 → 13.10). So obviously kernel, xorg, nvidia blob or something that changed during the update is to blame.
Asus MB & GTX 660 card.
You probably have a different problem since software suspend has never worked for me.
BTW, SysRq + K allows me to restart the X server, and the PC keeps on chugging on. It’s not really handy though as all X applications die in a process.
I’m having the same issue in Fedora 20 x86_64, with failure to resume from suspend.
Kernel 3.12.5/3.11.10 (happens with both)
NVIDIA 331.20 drivers from RPMFusion
MSI GeForce GTX 680 Lightning (factory OCed, but not any further)
ASUS P8P67 PRO
Core i5 2500K
But I do not have any problems with freezing/driver crashes in Windows 8.1.
This is what I have in my system logs:
Dez 25 11:55:26 daniel-pc kernel: NVRM: Xid (0000:01:00): 13, 0003 00000000 0000a097 00000c04 00a20000 00000000
Dez 25 11:55:26 daniel-pc kernel: NVRM: Xid (0000:01:00): 13, 0001 00000000 0000a097 00001614 00000000 00000000
Dez 25 11:55:26 daniel-pc kernel: NVRM: Xid (0000:01:00): 56, CMDre 00000001 00000080 00000000 00000005 0000000d
Dez 25 11:55:38 daniel-pc kernel: NVRM: Xid (0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00001005
Dez 25 11:55:52 daniel-pc kernel: NVRM: Xid (0000:01:00): 56, CMDre 00000001 00000080 00000000 00000005 0000000d
Dez 25 11:56:06 daniel-pc kernel: NVRM: Xid (0000:01:00): 56, CMDre 00000001 00000080 00000000 00000005 0000000d
Dez 25 11:56:32 daniel-pc kernel: NVRM: Xid (0000:01:00): 56, CMDre 00000001 00000080 00000000 00000005 0000000d
Dez 25 11:57:05 daniel-pc kernel: NVRM: Xid (0000:01:00): 56, CMDre 00000001 00000080 00000000 00000005 0000000d
Dez 25 11:57:29 daniel-pc kernel: NVRM: Xid (0000:01:00): 56, CMDre 00000001 00000080 00000000 00000005 0000000d
Hi ;
is it a problem with resume from suspend ?
If it is that ; it is possible to reinstall the patched version of hal and reinstall the nvidia driver again . for me it solved the issue on Kernel 3.11 because of some conflict beetween systemd and hal . now it works perfectly .
if you need the new patched hal : see ppa of Michael Blennerhassett .
LINK: https://launchpad.net/~mjblenner/+archive/ppa-hal?field.series_filter=saucy.
regards
Mounir
I don’t even have hal installed in my system.
In my case it’s a hardware/driver error, which NVIDIA doesn’t want to debug or help with.
Hi danielkza,
I’m facing the same problem as you on Fedora 20 x86_64. I did not have souch problem with F19 and older releases.
I have it on Lenovo T520 with Quadro NVS 4200M and Core i7-2670QM.
Few resumes are OK and than only reboot is possible from virtual console.
It seems that there is a such problem with 331.20 driver.
cgrim
i had the same problem with resume , the keyboard was dead , the mouse too . but after looking on nvidia installer log i have seen there were error with systemd . with a patched hal version , no error , no evo pusch problem . i installed powerbase management and powerwaked and the life is good .
This issue hasn’t been fixed.
I don’t use systemd, I’m on CentOS 6.5 running vanilla kernel (i686 with PAE).
And it’s still not fixed.
Under the current drivers (352.21) and kernel (4.1 i686 PAE) I cannot resume at all.
The system is simply dead on resume (even if I resume right after suspending).
There are no messages logged anywhere.
Just to add that I’m having the same issue:
[40279.151972] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000001 00000080 00000000 00000005 0000000b
[40279.152077] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000002 00000080 00000000 00000005 0000000b
[40279.166077] NVRM: Xid (PCI:0000:01:00): 13, Graphics Exception: Shader Program Header 1 Error
[40279.166186] NVRM: Xid (PCI:0000:01:00): 13, Graphics Exception: Shader Program Header 2 Error
[40279.166291] NVRM: Xid (PCI:0000:01:00): 13, Graphics Exception: Shader Program Header 3 Error
[40279.166393] NVRM: Xid (PCI:0000:01:00): 13, Graphics Exception: Shader Program Header 4 Error
[40279.166488] NVRM: Xid (PCI:0000:01:00): 13, Graphics Exception: Shader Program Header 9 Error
[40279.166597] NVRM: Xid (PCI:0000:01:00): 13, Graphics Exception: Shader Program Header 11 Error
[40279.166688] NVRM: Xid (PCI:0000:01:00): 13, Graphics Exception: Shader Program Header 18 Error
[40279.166781] NVRM: Xid (PCI:0000:01:00): 13, Graphics Exception: ESR 0x405840=0xa2040a1e
[40279.166888] NVRM: Xid (PCI:0000:01:00): 13, Graphics Exception: ChID 0003, Class 00009197, Offset 00002390, Data 00000000
[40279.275762] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000001 00000080 00000000 00000005 0000000b
[40279.275864] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000002 00000080 00000000 00000005 0000000b
[40279.276703] NVRM: Xid (PCI:0000:01:00): 13, Graphics Exception on GPC 0: SAVE_RESTORE_ADDR_OOB
[40279.276800] NVRM: Xid (PCI:0000:01:00): 13, Graphics Exception: ESR 0x500900=0x80000001
[40279.276918] NVRM: Xid (PCI:0000:01:00): 13, Graphics Exception: ChID 0004, Class 00009197, Offset 000023a8, Data 00000000
[40279.299329] NVRM: Xid (PCI:0000:01:00): 13, Graphics Exception: Shader Program Header 1 Error
[40279.299427] NVRM: Xid (PCI:0000:01:00): 13, Graphics Exception: Shader Program Header 2 Error
[40279.299514] NVRM: Xid (PCI:0000:01:00): 13, Graphics Exception: Shader Program Header 3 Error
[40279.299600] NVRM: Xid (PCI:0000:01:00): 13, Graphics Exception: Shader Program Header 4 Error
[40279.299684] NVRM: Xid (PCI:0000:01:00): 13, Graphics Exception: Shader Program Header 9 Error
[40279.299769] NVRM: Xid (PCI:0000:01:00): 13, Graphics Exception: Shader Program Header 18 Error
[40279.299854] NVRM: Xid (PCI:0000:01:00): 13, Graphics Exception: ESR 0x405840=0xa204021e
[40279.299954] NVRM: Xid (PCI:0000:01:00): 13, Graphics Exception: ChID 000f, Class 00009197, Offset 00002390, Data 00000007
same problem, sometimes after steam games, ubuntu 16.04, driver 375.39, GeForce GTX 1060 3GB
[17134.951276] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000001 000000a4 00010053 00000007 00000000
[17134.951505] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000001 000000c0 00010079 00000007 00000000
[17134.967976] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000001 000000a4 00010053 00000007 00000000
[17134.968215] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000001 000000c0 00010079 00000007 00000000
[17134.984565] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000001 000000a4 00010053 00000007 00000000
[17134.984801] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000001 000000c0 00010079 00000007 00000000
[17135.001235] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000001 000000a4 00010053 00000007 00000000
[17135.001469] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000001 000000c0 00010079 00000007 00000000
[17135.017935] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000001 000000a4 00010053 00000007 00000000
[17135.018139] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000001 000000c0 00010079 00000007 00000000
[17135.214832] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000474 00010076 00000007 00000000
