(This is a split from the nvcc lmem/alias analysis bug thread. We were getting offtopic.)
decuda is currently not useful for CUDA 3.x non beta releases because it appears that the release compilers do not allow you to generate the old CUBIN format rather than ELF, and decuda (in wumpus’ words) is currently missing ELF support because of the lack of good ELF libraries for Python. I don’t have time to write a proper ELF parser at the moment, but here’s a stopgap - it uses objdump to generate an ASCII dump of the ELF file, and parses that (paying attention to little details like endianness ;)) into an approximation of an old-style CUBIN. It’s certainly not perfect, and I offer no warranty whatsoever, but it seems to work for me. You’ll need objdump to be in your path for it to work. Call it as “python elfToCubin.py [ELF-style CUBIN file]” and it will dump an old-style CUBIN to stdout.
In addition to copying from the code box, you can download it here
Hopefully this will be useful for people both as a short-term stopgap until proper ELF support is built into decuda, and for decuda developers once a proper ELF parser can be put in place of calling objdump externally!
EDIT: The code below is out of date; grab the latest version from the link above. Leaving the old version below for posterity.
[codebox]
#!/usr/bin/python
Copyright 2010, Imran Haque
ihaque AT cs DOT stanford DOT edu
http://cs.stanford.edu/people/ihaque
This code is placed in the public domain and bears no warranty whatsoever
Uses objdump to dump contents of an nvcc-generated ELF file
and parses this output to generate an old-format CUBIN file
Notable shortcomings:
kernel .info sections are not parsed (presumably contains memory/reg info)
no attempt is made to preserve names of constant sections
does not parse size or proper name/offset of constant sections
emits initializer data for file-constant variables
import sys
import socket
from subprocess import Popen,PIPE
sys.stderr.write(“This script is out of date! Get the latest version at http://cs.stanford.edu/people/ihaque/elfTo…y\n”)
class cubin:
def __init__(self):
self.kernels = []
self.consts = []
self.arch = "sm_10"
self.abiversion = "1"
self.modname = "cubin"
def output(self,f):
f.write("architecture {%s}\n"%self.arch)
f.write("abiversion {%s}\n"%self.abiversion)
f.write("modname {%s}\n"%self.modname)
for c in self.consts:
c.output(f)
for k in self.kernels:
k.output(f)
class constant:
def __init__(self,name,data=None,depth=0,inkernel=False):
self.name = name
self.segname = "const"
self.segnum = 0
self.offset = 0
self.bytes = 0
self.depth = depth
self.mem = None
self.inkernel = inkernel
if data is not None:
self.mem = mem(data,self.depth+1)
def output(self,f):
prefix= "\t"*(self.depth+1)
shortprefix= "\t"*(self.depth)
if self.inkernel:
f.write("%sconst {\n"%shortprefix)
else:
f.write("%sconsts {\n"%shortprefix)
if self.name is not None:
f.write("%s\t\tname = %s\n"%(prefix,self.name))
f.write("%s\t\tsegname = %s\n"%(prefix,self.segname))
f.write("%s\t\tsegnum = %d\n"%(prefix,self.segnum))
f.write("%s\t\toffset = %d\n"%(prefix,self.offset))
f.write("%s\t\tbytes = %d\n"%(prefix,self.bytes))
if self.mem is not None:
f.write("%smem {\n"%prefix)
self.mem.output(f)
f.write("%s}\n"%prefix)
f.write("%s}\n"%shortprefix)
class kernel:
def __init__(self,name,buf_text=None,buf_const=None,buf_info=Non
e):
self.name = name
self.lmem = 0
self.smem = 0
self.reg = 0
self.bar = 0
self.offset = 0
self.bytes = 0
self.consts = []
self.code = None
if buf_text is not None:
self.code = mem(buf_text)
if buf_const is not None:
self.consts = [constant("%s0"%self.name,buf_const,1,True)]
if buf_info is not None:
self.info = mem(buf_info,1)
def output(self,f):
f.write("code {\n")
f.write("\tname = %s\n"%self.name)
f.write("\tlmem = %d\n"%self.lmem)
f.write("\tsmem = %d\n"%self.smem)
f.write("\treg = %d\n"%self.reg )
f.write("\tbar = %d\n"%self.bar )
c.output(f)
f.write("\tbincode {\n")
self.code.output(f)
f.write("\t}\n")
f.write("}\n")
class mem:
def __init__(self,data,depth=0,little_endian=True):
self.le = little_endian
self.data = []
self.append(data)
self.tabs = "\t"*(depth+2)
return
def append(self,data):
for i in data:
#print i
x = int(i,16)
if self.le:
# This sort of assumes that the file was built on the same arch where it's being disasm'd
x = socket.htonl(x)
self.data.append(x)
return
def output(self,f):
for i in range(0,len(self.data),4):
datastrs = ["0x%08x"%x for x in self.data[i:i+4]]
f.write("%s%s\n"%(self.tabs," ".join(datastrs)))
return
def parse_objdump(objdump):
# Parser states
START = 0
INKERNEL = 1
INFILECONST = 2
INKCONST = 3
INKINFO = 4
lines = [x.strip() for x in objdump.split(“\n”)]
format = lines[1].split("-")[-1]
little_endian = True
if format != "little":
little_endian = False
print "Warning, found a non-little-endian file"
buffer_text = []
buffer_const = []
buffer_info = []
state = START
kname = None
const_id = 0
file = cubin()
for line in lines[2:]:
#print "%%:",line
if len(line.strip()) == 0:
continue
if state == START: #{{{
if line.startswith("Contents of section .text"):
kname = line.split(".")[-1].rstrip(":")
state = INKERNEL
continue
elif len(line) == 0:
continue
else:
raise ValueError("Got unexpected line in state START\n%s"%line)
elif state == INKERNEL: #{{{
# Handle new kernel
# Store old kernel
file.kernels.append(kernel(kname,buffer_text,buffer_const,bu
ffer_info))
buffer_text = []
buffer_const = []
buffer_info = []
state = INKERNEL
continue
elif line.startswith("Contents of section .nv.constant"):
# Handle const data
if line.endswith("%s:"%kname):
state = INKCONST
continue
else:
# This is a file constant section
# Store old kernel
state = INFILECONST
ffer_info))
kname = None
buffer_text = []
buffer_const = []
buffer_info = []
continue
elif line.startswith("Contents of section .nv.info"):
# Handle kernel info
state = INKINFO
continue
elif line[0].isdigit():
# Handle new line of kernel binary
# Take hex dump from objdump, remove address and ASCIIization
buffer_text.extend(line[6:42].split())
else:
raise ValueError("Got unexpected line in state INKERNEL\n%s"%line)
elif state == INFILECONST: #{{{
# Handle new kernel
# Store old kernel
file.consts.append(constant("constant%d"%const_id,buffer_const))
buffer_const = []
const_id = 0
state = INKERNEL
continue
# Handle const data
# we should not be in a kernel here
# TODO make sure not in kernel
buffer_const = []
const_id = 0
state = INFILECONST
continue
raise ValueError("Error, got into an .nv.info section from a file const section")
buffer_const.extend(line[6:42].split())
else:
raise ValueError("Got unexpected line in state INFILECONST\n%s"%line)
elif state == INKCONST: #{{{
# Handle new kernel
# Store old kernel
ffer_info))
buffer_text = []
buffer_const = []
buffer_info = []
const_id = 0
state = INKERNEL
continue
# Handle const data
raise ValueError("Can't deal yet with kernels with multiple const sections")
else:
# Store old kernel
state = INFILECONST
file.append(kernel(kname,buffer_text,buffer_const,buffer_inf
o))
kname = None
buffer_text = []
buffer_const = []
buffer_info = []
const_id = 0
continue
state = INKINFO
continue
else:
raise ValueError("Got unexpected line in state INKCONST\n%s"%line)
elif state == INKINFO: #{{{
# Handle new kernel
# Store old kernel
ffer_info))
buffer_text = []
buffer_const = []
buffer_info = []
const_id = 0
state = INKERNEL
continue
# Handle const data
state = INKCONST
continue
else:
# Store old kernel
state = INFILECONST
ffer_info))
kname = None
buffer_text = []
buffer_const = []
buffer_info = []
continue
raise ValueError("Can't handle kernels with multiple INFO sections")
state = INKINFO
continue
buffer_info.extend(line[6:42].split())
else:
raise ValueError("Got unexpected line in state INKINFO\n%s"%line)
else:
raise ValueError("Hit an invalid state in parser")
if kname is None:
if len(buffer_const) > 0:
else:
ffer_info))
return file
if len(sys.argv) < 2:
print "Usage: elfToCubin [input file]"
sys.exit(1)
output = “”.join(Popen([“objdump”, “-s”, sys.argv[1]], stdout=PIPE).communicate()[0])
cubin = parse_objdump(output)
cubin.output(sys.stdout)
[/codebox]
