If you want to find out the total time recorded by the profiler, this is a simple script that may be useful.
The first step is to enable the profiler and use the comma separated format
The script ( total_time) is a simple one line of awk:
Once the log file has been generated (if the CUDA_PROFILE_LOG variable is not set, it will be named cuda_profile.log), you can simply invoke the script
Massimiliano
