Hi KevinFFF,
Thanks for the reply.
we are using Jetpack version 5.1.4. Yes, indeed the SD slot is from the carrier board. I have created a node sdhci_sd1: sdhci@3440000 by using refernce, no other changes were made.
Also i have created the image using command
sudo ROOTFS_DIR=./rootfs/ ./tools/jetson-disk-image-creator.sh -o jetpack514.img -b jetson-xavier-nx-devkit -r 01 -d SD
later burned it to sd card using dd command
sudo dd if=jetpack514.img of=/dev/sda bs=1M oflag=direct status=progress
Finally flashed the device with
sudo ./flash.sh jetson-xavier-nx-devkit-emmc mmcblk1p1
But still not able to boot the board. with logs from console.
[ 8.120273] Run /init as init process
[ 8.124971] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 8.124975] Extcon DP: HPD disabled
[ 8.124979] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 8.124988] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 8.127542] tegra_cec 3960000.tegra_cec: Can’t find physical address.
[ 8.127547] tefra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 8.137124] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 8.226966] Root device found: mmcblk1p1
[ 8.231553] tegra-i2c 3190000.i2c: I2C transfer timed out
��pll_d2 has no dyn ramp
��[ 8.252927] Found dev node: /dev/mmcblk1p1
[ 8.343567] tegra-i2c 3190000.i2c: I2C transfer timed out
[ 8.424940] EXT4-fs (mmcblk1p1): ext4_check_descriptors: Checksum for group 0 fail%d (7669!=1943)
[ 8.425145] EXT4-fs (mmcblk1p1): group descriptors corrupted!
[ 8.426583] ERROR: mmcblk1p1 mount fail…
[ 8.432372] Press [ENTER] to start bash…
[ 8.459548] tegra-i2c 3190000.i2c: I2C transfer timed out
[ 8.535528] usb 1-2.7: new high-speed USB device number 3 using tegra-xusb
[ 8.571531] tegra-i2c 3190000.i2c: I2C transfer timed out
[ 8.636664] usb 1-2.7: New USB device found, idVendor=0424, idProduct=2840, bcdDevice= 2.04
[ 8.636857] usb 1-2.7: New USB device stpings: Mfr=1, Product=2, SerialNumber=0
[ 8.637005] usb 1-2.7: Product: Hub Feature Controller
[ 8.637124] usb 1-2.7: Manufacturer: Microchip
Am i missing something?
Thanks,
Jai
