Hi All, I am using Nvidia Jetson Xavier NX A203 Version 2 Carrier Board. I am facing problem with SD Card and Ardu Cam IMX477 camera. Like when i insert sdcard, i need to enable it by updating the device tree and then sdcard is recognized but on the same side after sdcard is detected, I start using IMX477 cam on jetson xavier board, it won’t detectnthe camera or can say cam not working. Like in similar way when I use IMX477 arducam it works fine but sdcard is not detected. The problem is both won;t works together.
So, Please help me in this, I am new to device tree
To clarify this first, NX A203 is a custom board from other vendor, so my answer here may not be correct.
Actually it sounds like you didn’t flash a device tree that matches this board in the beginning. That is why you need to modify device tree after you flash the board.
Also, I am not sure how is your method to enable IMX477. What I guess is when you enable sdcard, you are using dtb_a. But when you are using IMX477 later, you are using dtb_b.
I guess it is just you are using two different device trees for different functions but not integrate them together at all.
To check whether I said is correct, you can dump the dmesg between these two cases.
Yes, when i am using imx477 then i run install4.sh which create dtb and when i enable sdcard it create new dtb so inshort i used two dtb for both. So my problem is how do i use both together. How to overcome conflicts between these two.
It is hard to directly answer as I already said, you are using a custom board.
I don’t know what is install4.sh and also not sure what is your process to create new dtb for sdcard.
A basic idea here is you just convert the two device tree from binary back to text. Compare the diff between them and put them into one file.
fragment@0 {
target = <&sdmmc3>;
__overlay__ {
status = "okay";
* We provide SD card function on carrier board, which supports CLK Frequency 48MHz.
* Increasing CLK by yourself might cause certificates (such as CE/FCC) failure!
max-clk-limit = <48000000>;
here’s another approach,
you may revise Xavier NX device tree to exclude IMX219, let the system probing IMX477 during kernel init as default camera.
for example, $public_sources/kernel_src/hardware/nvidia/platform/t19x/jakku/kernel-dts/common/tegra194-p3509-0000-a00.dtsi
