SD card is not booted on different Jetson Nano boards
I’ve used well Jetson Nano for several months. After I just setup the initial Ubuntu first boot setup and rebooted. And then the SD card works well in that Jetson Nano board which was used to for the first boot.
But the problem is that the SD card does not work at all on other Jetson Nano boards: If power is turned on, the green LED is lit continuously but any screen is not displayed. Monitor does not get any video signal. But that board works well if I use the SD card image which is provided by Nvidia site. And I cross-checked all the combinations of trials.
Is there some solution or some comment for this problem?
The image file used for the first boot is: jetson-nano-jp451-sd-card-image.zip
Thank you.
I just want to make sure what is the exact step to hit this issue.
So there are more than one jetson nano here?
So those modules are fine if you use the pure sdcard from our website, right?
Could you elaborate what are those jetpack version of these cards? Maybe you can name each card here so that we can get into the case easily.
I think the problematic card just worked again on the second jetson nano, right?
It is actually working after the second nano is installed with other sdcard image first.
: Yes, it did.
: Yes, it is.
But, as I said in my previous last post, all the problems have disappeared of itself suddenly. I don’t know the cause. So let’s close this issue. Thank you.
