SD CARD LOW WRITE SPEED
Hi
we have used a class 10 SD card in our TX1 reference board but the write speed is up to 6 M/Bps
we have tested this the same card in the laptop we are able to get 9 M/Bps the card we used in both the case is Sandisk Ultra 16GB class 10 micro SD HC Card but the data rate is low in Tegra How can this be increased
Hi agxin,
Please run below command and run SDcard write speed again:
sudo ./jetson_clocks.sh
