I ejected my sd card and tried to put it again and it is not locking place. Without the sd card locking in, the nano wouldn’t function.
Has anyone else faced this issue?
Hi indiandragon, you might want to try blowing into the slot in case there is some dirt or debris that might be preventing the SD card from locking into place. If possible you also might want to try pushing on the card a bit harder to engage the latch.
If you can’t get it to work, you could open an RMA, see here for the procedure: [url]https://developer.nvidia.com/embedded/faq#rma-process[/url]
Thanks for the reply.
I’ve tried the troubleshooting, but it didn’t work. I think the locking mechanism is faulty, I’ve requested for RMA.
