Following these instructions to load the image on the jetson orin nano SD and when the image is done flashing the drive splits into a lot of different drives. I tried loading it into the jetson anyway, but it does not seem to work as the monitor does not turn on. Has anyone had similar issues? I have tried it both with the image zipped and unzipped.
That’s normal; it will create a bunch of partitions with one large one left at the end. Do you at least see the Nvidia logo when booting? It should show that, then that disappears, then it will boot the full GUI.
If that doesn’t work try writing the image again.
Thank you so much! It ended up being an issue with the monitor, thank you for helping me to eliminate the sd card as the source of error.
