I am trying out the Cuda 4.0 RC on Ubuntu 10.10 (i686). After installing the following libraries:
sudo apt-get install libxi-dev libxmu-dev freeglut3-dev
I find that some of the SDK samples build, but not all of them. In particular the system errors out on freeImageInteropNPP:
make -C src/freeImageInteropNPP/
make[2]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/CUDALibraries/src/freeImageInteropNPP'
g++ -fPIC -I. -I../../common/UtilNPP/ -I../../common/FreeImage/include -I/usr/local/cuda/include/ -L../../common/lib -L/usr/local/cuda/lib -lcudart -lnpp -L../../common/FreeImage/lib/linux -o freeImageInteropNPP freeImageInteropNPP.cpp -lUtilNPP_i686 -lfreeimage32
/usr/bin/ld: cannot find -lUtilNPP_i686
collect2: ld returned 1 exit status
Has anyone else run into this, on 32-bit Ubuntu?
