Hi I have an avermedia carrierboard and AGX orin. I have installed their BSP without any major issues. I then tried to install the SDK components such as CUDA. SDK manager reported all ok apart from “BSP Patch” and “Multimedia” which have some sort of BSP mismatch.
I went back to the orin to see if CUDA is now on there but it reports that it is not installed. The BSP should be for 5.0.2 Rev 1 and that is the SDK components I am trying to install. Given that SDK manager reported CUDA and most the rest were fine, shouldn’t I see something on the jetson?
Aw ok. I used your command and it reported cuda as installed, so perhaps its just a JTOP issue. Here is the screenshot from the host and target machines incase there is anything interesting there for you to note with the failed installation items.
