SDK examples: -m32 on x86_64
Hi all,
I just got a little GPU to start tinkering with porting my application to CUDA, and I’m ran into some trouble building the SDK examples. Some build fine, but matrixMulDrv fails:
In file included from /usr/include/features.h:352,
from /usr/include/limits.h:27,
from /usr/lib/gcc/x86_64-redhat-linux/4.1.2/include/limits.h:122,
from /usr/lib/gcc/x86_64-redhat-linux/4.1.2/include/syslimits.h:7,
from /usr/lib/gcc/x86_64-redhat-linux/4.1.2/include/limits.h:11,
from /usr/local/cuda/bin/…/include/driver_types.h:48,
from /usr/local/cuda/bin/…/include/builtin_types.h:43,
from /usr/local/cuda/bin/…/include/cuda_runtime.h:45,
/usr/include/gnu/stubs.h:7:27: error: gnu/stubs-32.h: No such file or directory
make: *** [data/matrixMul_kernel.cubin] Error 255
The problem appears to be that x86_64 is not defined, which sets __WORDSIZE=32 and gives the error, because it should look for stubs-64.h. This in turn appears to be because common.mk hardcodes -m32 in the cubin compile lines. Changing this to -m64 allows the compile to continue, but this should probably be detected.
Cheers,
/Patrik
Thanks for pointing this out. An alternative workaround is to install the glibc-devel i386 RPM that ships with the OS.
Hi, I just wanted to point out that this is still an issue. I examined common/common.mk and there does appear to be some code to detect the architechture:
# detect if 32 bit or 64 bit system
HP_64 =	$(shell uname -m | grep 64)
... more code to set the actual flag
It didnt actually work for me and i had to manually set: CUBIN_ARCH_FLAG (at two locations). This is on Ubuntu 7.10.
Just wanted to point that out
I fixed it by moving the flag outside the unrelated OpenGL test.
Apologies for the silly syntax, just did a copy-paste job:
    ifeq "$(strip $(HP_64))" ""
    else
    CUBIN_ARCH_FLAG := -m64
    endif
Thanks for the solution to the build problem – worked for me on my x86_64.
However, running matrixMulDrv produces:
Processing time: 0.123000 (ms)
Test FAILED
Press ENTER to exit...
I tried changing the error threshold in matrixMulDrv.cpp from 1e-6 to 1e-5 and 1e-1, but got the same FAILED result.
All other programs in the SDK/bin/linux/release directory report Test PASSED.
Could this be related to the makefile change?
Thanks,
Scott
Update: I took a look at the two matrixMulDrv C matrices (result of C=A*B) – that is, the C computed by the GPU and by the host CPU. It looks like the CPU reports matrix entries 10-50 times greater than the GPU entries. Example: CPU=10.7613, GPU=0.8684.
Could there be a problem with my CUDA installation?
Thanks,
Scott
