SDK Failure to launch
I tried running the particles or smoke examples from CUDA v2.3 with a GTX 470, and I keep getting an “unspecified launch failure”. Any help? Only a ffew examples will not run, the others are fine
If you are using a GTX 470, you really should be using the CUDA >= 3.0 (3.1 was released just a few days ago) driver, toolkit and example packages.
