NVIDIA SDK Manager Startup Failure Report and Solution
1. Issue Summary
NVIDIA SDK Manager 2.4.1 failed to start from both the application menu and the terminal. The application window did not open reliably, and the process either exited or crashed with a segmentation fault.
The requirement was to solve the issue on the current kernel without switching to or downgrading the kernel.
2. System Environment
| Item | Detected Value |
| Hostname | wangxin-OptiPlex-7090 |
| Operating system | Ubuntu 24.04.4 LTS (Noble Numbat) |
| Kernel | 7.0.0-28-generic |
| Graphical session | Wayland with DISPLAY=:0 |
| SDK Manager | 2.4.1-13536 |
| SDK Manager GUI runtime | Electron 39.5.1 |
| Installation directory | /opt/nvidia/sdkmanager |
The operating system version above was read directly from /etc/os-release during diagnosis.
3. Symptoms and Evidence
3.1 AppArmor Denied Electron Sandbox Capabilities
The kernel audit log showed that SDK Manager created a user namespace and was then denied capabilities required by the Electron sandbox:
apparmor="AUDIT" operation="userns_create" profile="unconfined"
comm="sdkmanager-gui" execpath="/opt/nvidia/sdkmanager/sdkmanager-gui"
apparmor="DENIED" operation="capable"
profile="unprivileged_userns" capability=21 capname="sys_admin"
profile="unprivileged_userns" capability=18 capname="sys_chroot"
Electron and Chromium subsequently reported a sandbox initialization failure:
Check failed: sys_chroot("/proc/self/fdinfo/") == 0
FATAL: content/browser/zygote_host/zygote_host_impl_linux.cc:221
3.2 Null Pointer Crash in Wayland Window Handling
After a dedicated AppArmor rule was added, the permission denials stopped, but the application still crashed on its Wayland code path:
Received signal 11 SEGV_MAPERR 0000000001a8
The crash offset 0x379d494 was resolved with the official Electron 39.5.1 debugging symbols. It maps to the following function:
ui::WaylandWindow::GetBoundsInDIP() const
This identified the second failure as a null pointer access in Electron’s Wayland window handling. It was not caused by a missing NVIDIA GPU driver, a missing shared library, or a damaged user configuration cache.
4. Causes Excluded During Diagnosis
The SDK Manager Debian package was installed correctly.
The
chrome-sandboxfile had the correctroot:rootownership and4755permissions. -
The SDK Manager executable had no missing shared-library dependencies.
The crash still occurred with a new XDG configuration directory, excluding damaged application caches.
Software rendering alone did not solve the issue.
The
--no-sandboxoption alone still resulted in a segmentation fault and was not a suitable solution. -
Removing only
WAYLAND_DISPLAYwas not sufficient to force Electron to use X11.
5. Root Cause
The startup failure was caused by two independent issues:
Ubuntu’s AppArmor policy for unprivileged user namespaces did not include an application-specific rule for SDK Manager. As a result, the Electron sandbox was denied the required
sys_adminandsys_chrootcapabilities. -
Electron 39.5.1, bundled with SDK Manager 2.4.1, encountered a null pointer access in
WaylandWindow::GetBoundsInDIP()in the current Wayland environment.
A complete solution therefore had to address both the AppArmor sandbox policy and the Wayland compatibility problem.
6. Implemented Solution
6.1 Dedicated AppArmor Rule for SDK Manager
The following profile was installed at /etc/apparmor.d/sdkmanager:
# Allow NVIDIA SDK Manager's Electron sandbox to create a user namespace.
abi <abi/4.0>,
include <tunables/global>
profile sdkmanager /opt/nvidia/sdkmanager/sdkmanager-gui flags=(unconfined) {
userns,
include if exists <local/sdkmanager>
The profile is loaded with:
sudo apparmor_parser -r /etc/apparmor.d/sdkmanager
This rule applies only to /opt/nvidia/sdkmanager/sdkmanager-gui. It does not disable AppArmor globally and does not disable the system-wide user namespace restriction.
6.2 Run SDK Manager Through XWayland/X11
A user-level desktop entry was created at:
~/.local/share/applications/sdkmanager.desktop
Its launch command is:
Exec=env --unset=WAYLAND_DISPLAY XDG_SESSION_TYPE=x11 /opt/nvidia/sdkmanager/sdkmanager-gui %U
This changes the graphical backend only for the SDK Manager process. The desktop session itself remains on Wayland.
The equivalent terminal command is:
env --unset=WAYLAND_DISPLAY XDG_SESSION_TYPE=x11 \
7. Verification Results
SDK Manager was tested with the corrected desktop launch environment. The results were:
The main SDK Manager process remained running.
Electron zygote child processes were created normally.
The SDK Manager background worker and download service were created normally.
The systemd user service reported an
activestate. -
No new SDK Manager AppArmor
DENIEDrecords appeared during verification. -
No new SDK Manager segmentation faults appeared during verification.
The main processes observed during verification included:
/opt/nvidia/sdkmanager/sdkmanager-gui --type=zygote
.../spawn-worker.js
.../downloadService.bundle.js
8. Normal Usage
Open SDKManager directly from the Ubuntu application menu. The user-level desktop entry overrides the package-provided system entry and automatically applies the X11 compatibility environment.
Useful diagnostic commands:
pgrep -a -f '^/opt/nvidia/sdkmanager/sdkmanager-gui'
journalctl -k --since today --no-pager | \
grep -Ei 'sdkmanager|apparmor.*DENIED|segfault'
9. Checks After an SDK Manager Upgrade
After upgrading SDK Manager, check the installed version and confirm that the compatibility configuration is still present:
dpkg-query -W -f='${Version}\n' sdkmanager
grep '^Exec=' ~/.local/share/applications/sdkmanager.desktop
If a later SDK Manager release fixes the Electron Wayland issue, native Wayland operation can be tested temporarily with:
The user-level X11 override should be removed only after native startup remains stable and the kernel log shows no segmentation faults.
10. Rollback Procedure
To remove the changes made by this solution:
unlink ~/.local/share/applications/sdkmanager.desktop
sudo apparmor_parser -R /etc/apparmor.d/sdkmanager
sudo unlink /etc/apparmor.d/sdkmanager
update-desktop-database ~/.local/share/applications
After rollback, SDK Manager will use the package-provided startup configuration again. The original failure may return with the current software and graphical environment combination.
11. Final Status
SDK Manager now starts successfully on Ubuntu 24.04.4 with Linux kernel 7.0.0-28-generic while the desktop remains in a Wayland session. The solution uses a dedicated AppArmor rule and a process-specific XWayland compatibility configuration. No kernel downgrade or kernel switch is required.
