Sdk manager and login problem tjetson nano
have downloaded through SDK MANAGER everything necessary to configure my JETSON NANO, but when I get to the part that you see in the image it does not let me continue due to problems with Incorrect username or password. Please try again.
What could be the problem? thank you
Hi cbenglenok,
Is there any error if you open a terminal window and try to ssh to the Jetson Nano with the same IP address, username, and password in it?
I had some problems with the USB cable, now it works. Thanks a lot.
