I use SDK_manager-0.9.13 to install cuda to TX2 by ethernet. But still have errors:
19:31:39 INFO : CUDA Toolkit for L4T : [target] [sudo] password for nvidia:
19:31:39 INFO : CUDA Toolkit for L4T : Reading package lists...
19:31:39 INFO : CUDA Toolkit for L4T : Building dependency tree...
19:31:39 INFO : CUDA Toolkit for L4T : Reading state information...
19:31:39 INFO : CUDA Toolkit for L4T : E: Unable to locate package libfreeimage-dev
19:31:39 INFO : CUDA Toolkit for L4T : E: Unable to locate package libopenmpi-dev
19:31:39 INFO : CUDA Toolkit for L4T : E: Unable to locate package openmpi-bin
19:31:39 INFO : CUDA Toolkit for L4T : Unhandled error when running sudo apt-get install -y gnupg libgomp1 libfreeimage-dev libopenmpi-dev openmpi-bin
19:31:39 INFO : CUDA Toolkit for L4T : exit status 1
19:31:39 INFO : CUDA Toolkit for L4T : [ Package PostInstall Finished with Error ]
19:31:39 ERROR : CUDA Toolkit for L4T : NV_L4T_CUDA_TARGET_POST_INSTALL_COMP command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh nvidia@192.168.2.208:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.2.208 "~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh" finished with error
19:31:39 INFO : CUDA Toolkit for L4T : [ 32.00 KB used. Disk Avail: 57.40 GB ]
19:31:39 INFO : CUDA Toolkit for L4T : [ NV_L4T_CUDA_TARGET_POST_INSTALL_COMP Install took 2m8s ]
19:31:39 INFO : CUDA Toolkit for L4T : command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh nvidia@192.168.2.208:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.2.208 "~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh" finished with error
19:31:39 ERROR : CUDA Toolkit for L4T : command terminated with error
I have tried these commands, but it doesn’t work.
sudo apt update
sudo apt --fix-broken install
sudo apt-get install libgconf-2-4 libcanberra-gtk-module python
I manually install libfreeimage-dev by ssh.but:
Reading package lists... Done
Reading state information... Done
