I’m trying to setup a new Jetson AGX Xavier development kit but SDK Manager hangs when trying to install the Jetson SDK Components.
All the components show “Install Pending” as the status. The progress bar is stuck at Installing: 33.33%.
The Jetson has flashed properly and I can login both interactively and via SSH (both on the wired network and the USB connection with the default 192.168.55.1 address). The sdkm
log shows a bunch of errors similar to this one:
16:27:12.590 - info: hello
16:27:12.591 - info: cmd finished success SDKM_END_CODE_SUCCESS_72a44c02-de94-42fb-ad92-3956b9cad19b
16:27:12.591 - info: command finished successfully
16:27:12.595 - info: Validated its username and password.
16:27:12.602 - info: cmd finished success SDKM_END_CODE_SUCCESS_f36a84ee-e65a-446f-9c73-bd6c55322587
16:27:12.603 - info: command finished successfully
16:27:12.636 - info: Using GenericInstaller to Query NV_L4T_CUDA_TARGET_POST_INSTALL_COMP
16:27:12.637 - info: change working directory to /tmp
16:27:12.637 - info: exec_command: ssh -F /dev/null -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no andreac@192.168.55.1 "dpkg-query -W -f='\${db:Status-abbrev} \${Version}' cuda-toolkit-10-2"
16:29:12.734 - info: terminal waiting for incoming message timeout
16:29:12.734 - info: Enter passphrase for key '/home/andreac/.ssh/id_rsa':
16:29:12.734 - info: auto filling '\r'
16:29:12.734 - info: "\r"
16:29:12.739 - info:
16:29:12.739 - info: [target] andreac@192.168.55.1's password:
16:29:12.739 - info: [TARGET PASSWORD]
16:29:12.744 - info:
16:29:12.744 - info: Target Deb package [{cuda-toolkit-10-2 10.2}] not installed; [deb_name]: cuda-repo-l4t-10-2-local-10.2.89_1.0-1_arm64.deb
16:29:12.745 - error: cmd finished failure SDKM_END_CODE_FAILURE_7d218507-fc82-40d2-8239-72eb335fb9cf_67
16:29:12.745 - error: command error code: 67
16:29:12.748 - info: Event: - error code is: 1067
16:29:12.748 - warn: Failed to get component from group data map for
16:29:12.748 - error: command terminated with error
16:29:12.752 - error: Failed: using adapter to query target component: NV_L4T_CUDA_TARGET_POST_INSTALL_COMP version: 10.2 for bundle:
16:29:12.757 - info: cmd finished success SDKM_END_CODE_SUCCESS_5fbc0764-1854-455a-94a9-dc8ce0cb02e3
16:29:12.757 - info: command finished successfully
How do I fix it?
