Sdk MANAGER could not install all the packages got stuck at step 1
Software Version
DRIVE OS 6.0.10.0
[*] DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] DRIVE AGX Orin Developer Kit (940-63710-0010-200)
other
SDK Manager Version
[*] 2.1.0
other
Host Machine Version
[*] other
Issue Description
sdk MANAGER could not install all the packages got stuck at step 1 , Development environment NOT going to Step 2
Ubuntu 22.04
Error String
< Please provide just the error messages here >
Logs
Provide logs in text box instead of image
Please paste the complete application log here. If there are multiple logs, please use multiple text box
Can you provide the full log of SDK manager?
Pls let me know how to get the SDK manager logs since this is the first time I am trying to install encountered this issue.
just fyi, When
I did install the same on Ubuntu 20.04 it was fine but when I am installing first time on Ubuntu 22.04 it’s not going through first step even.
Thanks,
Sudarsanarao
I mean pls check is there any limitations with Ubuntu 22.04 for the Drive0s 6.0.8?
Dear @sudarsanarao.makupalli.yg ,
The host requirement is to use ubuntu 20.04 to flash DRIVE Orin and hence sdkmanager does not show it
When will be supporting on Ubuntu 22.04 since ubuntu20.4 support is being stopped from Ubuntu community.
Thanks,
Sudarsanarao
Currently, There are no DRIVE OS releases targetted for DRIVE AGX Orin devkit. We have stopped DRIVE OS releases on sdkamanager since DRIVE OS 6.0.6.
Please use ubuntu 20.04 based platform. You can install DRIVE OS 6.0.10
using docker (Install DRIVE OS 6.0.10.0 for NVIDIA Developer Users | NVIDIA Docs)
