I want to flash my jetson nano through the sdk manager but why I can’t log in my nvidia acount even I modify my password for several times!
I have the same problem. Can not login on the SDK manager
And I found that you can’t log in nvidia account through entering e-mail address and password in the login user interface
I am also in the same boat. I cannot log in.
This is the same problem I guess: https://devtalk.nvidia.com/default/topic/1058277/sdk-manager-password-no-longer-recognized/
But without an answer either. I have the same problem btw.
Hi guys, thanks for reporting this, we are looking into it now.
OK, if you try logging in again now, access should be restored. Let us know if you are still unable to login - thanks.
I’m having the same issue. It worked for me just 2 hours ago. Now all over sudden it says my credentials are wrong. Login works on the nvidia page just fine
edit: starting the sdkmanager over the menu instead of the terminal somehow resolved the issue
The same issue just happened to me right now. Help, please.
Make sure you’ve selected the regular devel site and not the NVIDIA partners site.
I have.
For some strange reason I was blocked out for 30min. Now everything works properly.
