SDK Manager fail to flash developer kit due Docker password error
I’m trying to flash Ubuntu 22.04 in a AGX Orin Developer kit, but it’s failing.
The error message is:
15:09:11 ERROR: Jetson Docker Image - target_image: [exec_command]: /bin/bash -c /home/ubuntu/.nvsdkm/replays/scripts/JetPack_6.2.1_Linux/JETSON_DOCKER_IMAGE_COMP.sh; [error]: Invalid password.
Any idea to how get the right docker password?
Thanks,
Carlos
I’m happy to help you with your issue, but I have to say that the provided context doesn’t seem to be directly related to your problem. The context appears to be a collection of documentation on flashing and configuring Jetson AGX Orin devices, but it doesn’t mention anything about Ubuntu 2204 or Docker passwords.
That being said, I’ll try to provide some general guidance on how to approach your issue.
To flash Ubuntu 2204 on a Jetson AGX Orin Developer Kit, you’ll need to follow the official NVIDIA documentation for installing Linux on the device. The process typically involves downloading the Linux for Tegra (L4T) package, extracting it, and then running the flash.sh script to flash the device.
Regarding the Docker password, I’m not sure what you’re referring to. Could you please provide more context or clarify what you mean by “Docker password”? Are you trying to use Docker on the Jetson device, or is this related to the flashing process?
To troubleshoot your issue, I recommend checking the following:
  1. Make sure you’re using the correct L4T package and following the official NVIDIA documentation for flashing the device.
  2. Verify that you have the necessary dependencies and tools installed on your host machine.
  3. Check the console output for any error messages that might indicate what’s going wrong.
  4. If you’re using Docker, ensure that you have the correct Docker image and configuration for the Jetson device.
If you could provide more information about your issue, such as the exact error message you’re seeing, I may be able to offer more specific guidance.
~0924
What is your host pc?
Is it native ubuntu or a vm/docker?
