SDK Manager fails to flash
hi
Unable to use Orin to flash successfully under SDK GUI.
SDK flash cannot be used successfully on the carrier board +nvme developed by our company.
NV Xavire devkit+USB disk also has the same error.
How to use the command: /tools/kernel_flash/l4t_initrd_flash.sh can flash successfully.
Change the module to Jetson Xavier NX/Nano (Ubuntu 18.04) SDK flash ok.
Best regards,
SDKM_logs_JetPack_5.1.2_Linux_for_Jetson_Orin_Nano_modules_2023-11-03_16-11-09.zip (217.6 KB)
SDK Manager不能燒你們自己做的custom board是正常的…
SDK Manager只支援Orin NX+Orin Nano DevKit (P3768)的組合、就算是Xavier NX DevKit (P3509) 也不行
請你們先找一片Orin Nano DevKit、確認module是沒問題的
接著再看用initrd flash的話你們的device tree, pinmux, BCT等東西有什麼要改的
還有你的flashing log只看得到最後階段timeout,但是有很多原因都會導致這個情況
所以只看flashing log沒辦法知道真正的問題,麻煩請你們也抓一下serial console log
