I am having issues upgrading my AGX to Drive10,
This is one of the error I am getting from the log.
09:11:54 INFO : OSS and NV packages : Some packages could not be installed. This may mean that you have
09:11:54 INFO : OSS and NV packages : requested an impossible situation or if you are using the unstable
09:11:54 INFO : OSS and NV packages : distribution that some required packages have not yet been created
09:11:54 INFO : OSS and NV packages : or been moved out of Incoming.
09:11:54 INFO : OSS and NV packages : The following information may help to resolve the situation:
09:11:54 INFO : OSS and NV packages : The following packages have unmet dependencies:
09:11:54 INFO : OSS and NV packages : gcc-7-multilib : Depends: lib32gcc-7-dev (= 7.4.0-1ubuntu1~18.04.1) but it is not going to be installed
09:11:54 INFO : OSS and NV packages : Depends: libx32gcc-7-dev (= 7.4.0-1ubuntu1~18.04.1) but it is not going to be installed
09:11:54 ERROR : OSS and NV packages : E: Unable to correct problems, you have held broken packages.
09:11:54 INFO : OSS and NV packages : ERROR: gcc-7-multilib failed to install
09:11:54 INFO : OSS and NV packages : Non interactive mode on : Triggering exit
09:11:54 INFO : OSS and NV packages : Exiting.
09:11:54 ERROR : OSS and NV packages : ERROR: Installation failed.
09:11:54 INFO : OSS and NV packages : exit status 1
09:11:54 INFO : OSS and NV packages : [ Package Install Finished with Error ]
09:11:54 INFO : OSS and NV packages : [ 160.00 KB used. Disk Avail: 529.09 GB ]
09:11:54 INFO : OSS and NV packages : [ NV_OSS_AND_NV_PACKAGES_SDK_COMP Install took 18s ]
09:11:54 ERROR : OSS and NV packages : execution command /home/marco/DriveWorksDocker/dnn7-download/drive-t186ref-linux-5.1.6.1-16911241-oss-minimal-sdk.run --nox11 returns 1
09:11:54 ERROR : OSS and NV packages : command terminated with error
Seems like sdk manager is unable to install some dependencies. Has anybody else encountered this issue?
I’m using Ubuntu 18.04
Following the dependencies rabbit hole I ended here it seems like I need ubuntu16? but the sdk says that to upgrade to Drive10 I need Ubuntu18:
Blade:~$ sudo apt install gcc-7-multilib
Reading package lists... Done
Building dependency tree
Reading state information... Done
Blade:~$ sudo apt install lib32gcc
lib32gcc1 lib32gcc1-dbg-ppc64-cross lib32gcc1-ppc64-cross lib32gcc-5-dev-mips64-cross lib32gcc-6-dev lib32gcc-6-dev-sparc64-cross lib32gcc-7-dev-ppc64-cross lib32gcc-8-dev-mips64-cross
lib32gcc1-amd64-cross lib32gcc1-dbg-s390x-cross lib32gcc1-s390x-cross lib32gcc-5-dev-mips64el-cross lib32gcc-6-dev-amd64-cross lib32gcc-6-dev-x32-cross lib32gcc-7-dev-s390x-cross lib32gcc-8-dev-mips64el-cross
lib32gcc1-dbg lib32gcc1-dbg-sparc64-cross lib32gcc1-sparc64-cross lib32gcc-5-dev-ppc64-cross lib32gcc-6-dev-mips64-cross lib32gcc-7-dev lib32gcc-7-dev-sparc64-cross lib32gcc-8-dev-ppc64-cross
lib32gcc1-dbg-amd64-cross lib32gcc1-dbg-x32-cross lib32gcc1-x32-cross lib32gcc-5-dev-s390x-cross lib32gcc-6-dev-mips64el-cross lib32gcc-7-dev-amd64-cross lib32gcc-7-dev-x32-cross lib32gcc-8-dev-s390x-cross
lib32gcc1-dbg-mips64-cross lib32gcc1-mips64-cross lib32gcc-4.8-dev lib32gcc-5-dev-sparc64-cross lib32gcc-6-dev-ppc64-cross lib32gcc-7-dev-mips64-cross lib32gcc-8-dev lib32gcc-8-dev-sparc64-cross
lib32gcc1-dbg-mips64el-cross lib32gcc1-mips64el-cross lib32gcc-5-dev lib32gcc-5-dev-x32-cross lib32gcc-6-dev-s390x-cross lib32gcc-7-dev-mips64el-cross lib32gcc-8-dev-amd64-cross lib32gcc-8-dev-x32-cross
Blade:~$ sudo apt install lib32gcc-7-dev
lib32gcc-7-dev : Depends: lib32mpx2 (>= 7.4.0-1ubuntu1~18.04.1) but it is not going to be installed
Blade:~$ sudo apt install lib32mpx2
lib32mpx2 : Depends: gcc-8-base (= 8.3.0-6ubuntu1~18.04.1) but 8.3.0-16ubuntu3~16.04 is to be installed
Blade:~$ sudo apt install gcc-8-base
gcc-8-base is already the newest version (8.3.0-16ubuntu3~16.04).
gcc-8-base set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
