I am trying to install L4T image on Xavier SDK. I have the SDK manager v4.3 on my host machine. The procedure fails due to libvisionworks. I have chosen the Download and Install paths on a external drive, hopefully that should
not create any problems.
The log is below:
14:50:01 INFO : VisionWorks on Host : verifying checksum of /media/imperiumdrive/MyPassport/vortex/Downloads/libvisionworks-repo_1.6.0.500n_amd64.deb
14:50:02 INFO : VisionWorks on Host : verifying checksum of /media/imperiumdrive/MyPassport/vortex/Downloads/libvisionworks-sfm-repo_0.90.4_amd64.deb
14:50:05 INFO : VisionWorks on Host : Found file /media/imperiumdrive/MyPassport/vortex/Downloads/libvisionworks-repo_1.6.0.500n_amd64.deb with correct checksum, skip downloading.
14:50:05 INFO : VisionWorks on Host : verifying checksum of /media/imperiumdrive/MyPassport/vortex/Downloads/libvisionworks-tracking-repo_0.88.2_amd64.deb
14:50:07 INFO : VisionWorks on Host : verifying checksum of /media/imperiumdrive/MyPassport/vortex/Downloads/NVIDIA_VisionWorks_References.zip
14:50:08 INFO : VisionWorks on Host : Found file /media/imperiumdrive/MyPassport/vortex/Downloads/libvisionworks-sfm-repo_0.90.4_amd64.deb with correct checksum, skip downloading.
14:50:09 INFO : VisionWorks on Host : Found file /media/imperiumdrive/MyPassport/vortex/Downloads/NVIDIA_VisionWorks_References.zip with correct checksum, skip downloading.
14:50:10 INFO : VisionWorks on Host : Found file /media/imperiumdrive/MyPassport/vortex/Downloads/libvisionworks-tracking-repo_0.88.2_amd64.deb with correct checksum, skip downloading.
14:50:10 INFO : VisionWorks on Host : Download 'VisionWorks on Host' success
14:50:10 INFO : VisionWorks on Host : Start to install 'VisionWorks on Host'
14:50:11 DEBUG : VisionWorks on Host : using adapter to install NV_VISIONWORKS_HOST_COMP@host to /media/imperiumdrive/MyPassport/vortex/nvidia/nvidia_sdk/JetPack_4.3_Linux
14:50:12 INFO : VisionWorks on Host : [ Disk Avail:12.55 GB ]
14:50:12 INFO : VisionWorks on Host : Using GenericInstaller to Install NV_VISIONWORKS_HOST_COMP
14:50:12 INFO : VisionWorks on Host : NV_VISIONWORKS_HOST_COMP include 4 package
14:50:12 INFO : VisionWorks on Host : [ Package Install Started ]
14:50:12 INFO : VisionWorks on Host : deb installer start to install
14:50:12 INFO : VisionWorks on Host : exec_command: dpkg -f /media/imperiumdrive/MyPassport/vortex/Downloads/libvisionworks-repo_1.6.0.500n_amd64.deb Package | tr -d '\n'
14:50:13 INFO : VisionWorks on Host : exec_command: dpkg -f /media/imperiumdrive/MyPassport/vortex/Downloads/libvisionworks-repo_1.6.0.500n_amd64.deb Version | tr -d '\n'
14:50:15 INFO : VisionWorks on Host : deb file /media/imperiumdrive/MyPassport/vortex/Downloads/libvisionworks-repo_1.6.0.500n_amd64.deb, package name [libvisionworks-repo], package version [1.6.0.500n]
14:50:15 INFO : VisionWorks on Host : infer package info from file name libvisionworks-repo_1.6.0.500n_amd64.deb [ name: libvisionworks-repo, version: 1.6.0.500n ]
14:50:15 INFO : VisionWorks on Host : exec_command: sudo -E apt-get install -y --allow-downgrades '/media/imperiumdrive/MyPassport/vortex/Downloads/libvisionworks-repo_1.6.0.500n_amd64.deb'
14:50:17 INFO : VisionWorks on Host : [host] [sudo] password for imperiumdrive:
14:50:19 INFO : VisionWorks on Host : Reading package lists...
14:50:19 INFO : VisionWorks on Host : Building dependency tree...
14:50:19 INFO : VisionWorks on Host : Reading state information...
14:50:19 INFO : VisionWorks on Host : libvisionworks-repo is already the newest version (1.6.0.500n).
14:50:19 INFO : VisionWorks on Host : The following packages were automatically installed and are no longer required:
14:50:19 INFO : VisionWorks on Host : gyp libc-ares2 libhttp-parser2.7.1 libjs-async libjs-inherits
14:50:19 INFO : VisionWorks on Host : libjs-node-uuid libjs-underscore libuv1-dev node-abbrev node-ansi
14:50:19 INFO : VisionWorks on Host : node-ansi-color-table node-archy node-async node-balanced-match
14:50:19 INFO : VisionWorks on Host : node-block-stream node-brace-expansion node-builtin-modules
14:50:19 INFO : VisionWorks on Host : node-combined-stream node-concat-map node-cookie-jar node-delayed-stream
14:50:19 INFO : VisionWorks on Host : node-forever-agent node-form-data node-fs.realpath node-fstream
14:50:19 INFO : VisionWorks on Host : node-fstream-ignore node-github-url-from-git node-glob node-graceful-fs
14:50:19 INFO : VisionWorks on Host : node-hosted-git-info node-inflight node-inherits node-ini
14:50:19 INFO : VisionWorks on Host : node-is-builtin-module node-isexe node-json-stringify-safe node-lockfile
14:50:19 INFO : VisionWorks on Host : node-lru-cache node-mime node-minimatch node-mkdirp node-mute-stream
14:50:19 INFO : VisionWorks on Host : node-node-uuid node-nopt node-normalize-package-data node-npmlog node-once
14:50:19 INFO : VisionWorks on Host : node-osenv node-path-is-absolute node-pseudomap node-qs node-read
14:50:19 INFO : VisionWorks on Host : node-read-package-json node-request node-retry node-rimraf node-semver
14:50:19 INFO : VisionWorks on Host : node-sha node-slide node-spdx-correct node-spdx-expression-parse
14:50:19 INFO : VisionWorks on Host : node-spdx-license-ids node-tar node-tunnel-agent node-underscore
14:50:19 INFO : VisionWorks on Host : node-validate-npm-package-license node-which node-wrappy node-yallist nodejs
14:50:19 INFO : VisionWorks on Host : nodejs-doc
14:50:19 INFO : VisionWorks on Host : Use 'sudo apt autoremove' to remove them.
14:50:20 INFO : VisionWorks on Host : 0 upgraded, 0 newly installed, 0 to remove and 66 not upgraded.
14:50:20 INFO : VisionWorks on Host : exec_command: dpkg -L libvisionworks-repo | grep 'GPGKEY$' | tr -d '\n'
14:50:21 INFO : VisionWorks on Host : exec_command: sudo apt-key add /var/visionworks-repo/GPGKEY
14:50:22 WARNING : VisionWorks on Host : Warning: apt-key output should not be parsed (stdout is not a terminal)
14:50:25 INFO : VisionWorks on Host : OK
14:50:25 INFO : VisionWorks on Host : exec_command: sudo apt-get check
14:50:27 INFO : VisionWorks on Host : Reading package lists...
14:50:27 INFO : VisionWorks on Host : Building dependency tree...
14:50:27 INFO : VisionWorks on Host : Reading state information...
14:50:27 INFO : VisionWorks on Host : exec_command: sudo apt-get update; sleep 0.5; sudo apt-get -y install libvisionworks=1.6.0.500n* libvisionworks-dev=1.6.0.500n* libvisionworks-samples=1.6.0.500n*
14:50:28 INFO : VisionWorks on Host : Get:1 file:/var/cuda-repo-10-0-local-10.0.326-410.108 InRelease
14:50:28 INFO : VisionWorks on Host : Ign:1 file:/var/cuda-repo-10-0-local-10.0.326-410.108 InRelease
14:50:28 INFO : VisionWorks on Host : Get:2 file:/var/cuda-repo-10-0-local-10.0.326-cross-aarch64 InRelease
14:50:28 INFO : VisionWorks on Host : Ign:2 file:/var/cuda-repo-10-0-local-10.0.326-cross-aarch64 InRelease
14:50:28 INFO : VisionWorks on Host : Get:3 file:/var/cuda-repo-10-2-local-10.2.89-440.40 InRelease
14:50:28 INFO : VisionWorks on Host : Ign:3 file:/var/cuda-repo-10-2-local-10.2.89-440.40 InRelease
14:50:28 INFO : VisionWorks on Host : Get:4 file:/var/cuda-repo-10-2-local-10.2.89-cross-aarch64 InRelease
14:50:28 INFO : VisionWorks on Host : Ign:4 file:/var/cuda-repo-10-2-local-10.2.89-cross-aarch64 InRelease
14:50:28 INFO : VisionWorks on Host : Get:5 file:/var/visionworks-repo InRelease
14:50:28 INFO : VisionWorks on Host : Ign:5 file:/var/visionworks-repo InRelease
14:50:28 INFO : VisionWorks on Host : Get:6 file:/var/visionworks-sfm-repo InRelease
14:50:28 INFO : VisionWorks on Host : Ign:6 file:/var/visionworks-sfm-repo InRelease
14:50:28 INFO : VisionWorks on Host : Get:7 file:/var/visionworks-tracking-repo InRelease
14:50:28 INFO : VisionWorks on Host : Ign:7 file:/var/visionworks-tracking-repo InRelease
14:50:28 INFO : VisionWorks on Host : Get:8 file:/var/cuda-repo-10-0-local-10.0.326-410.108 Release [574 B]
14:50:28 INFO : VisionWorks on Host : Get:9 file:/var/cuda-repo-10-0-local-10.0.326-cross-aarch64 Release [574 B]
14:50:28 INFO : VisionWorks on Host : Get:10 file:/var/cuda-repo-10-2-local-10.2.89-440.40 Release [574 B]
14:50:28 INFO : VisionWorks on Host : Get:11 file:/var/cuda-repo-10-2-local-10.2.89-cross-aarch64 Release [574 B]
14:50:28 INFO : VisionWorks on Host : Get:12 file:/var/visionworks-repo Release [1,999 B]
14:50:28 INFO : VisionWorks on Host : Get:13 file:/var/visionworks-sfm-repo Release [2,003 B]
14:50:28 INFO : VisionWorks on Host : Get:14 file:/var/visionworks-tracking-repo Release [2,008 B]
14:50:28 INFO : VisionWorks on Host : Get:15 file:/var/visionworks-repo Release.gpg [819 B]
14:50:28 INFO : VisionWorks on Host : Get:16 http://security.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
14:50:28 INFO : VisionWorks on Host : Hit:17 http://ppa.launchpad.net/webupd8team/java/ubuntu bionic InRelease
14:50:28 INFO : VisionWorks on Host : Hit:18 http://packages.microsoft.com/repos/vscode stable InRelease
14:50:28 INFO : VisionWorks on Host : Ign:20 http://dl.google.com/linux/chrome/deb stable InRelease
14:50:28 INFO : VisionWorks on Host : Hit:21 https://packages.microsoft.com/ubuntu/19.10/prod eoan InRelease
14:50:28 INFO : VisionWorks on Host : Hit:22 http://packages.ros.org/ros/ubuntu bionic InRelease
14:50:28 INFO : VisionWorks on Host : Hit:23 http://packages.cloud.google.com/apt cloud-sdk-bionic InRelease
14:50:28 INFO : VisionWorks on Host : Hit:24 http://packages.ros.org/ros2/ubuntu bionic InRelease
14:50:28 INFO : VisionWorks on Host : Hit:25 http://dl.google.com/linux/chrome/deb stable Release
14:50:28 INFO : VisionWorks on Host : Hit:26 http://de.archive.ubuntu.com/ubuntu bionic InRelease
14:50:28 INFO : VisionWorks on Host : Hit:27 http://de.archive.ubuntu.com/ubuntu bionic-updates InRelease
14:50:28 INFO : VisionWorks on Host : Hit:29 http://de.archive.ubuntu.com/ubuntu bionic-backports InRelease
14:50:29 INFO : VisionWorks on Host : Hit:31 https://packagecloud.io/slacktechnologies/slack/debian jessie InRelease
14:50:34 INFO : VisionWorks on Host : Fetched 88.7 kB in 6s (14.2 kB/s)
14:50:35 INFO : VisionWorks on Host : Reading package lists...
14:50:36 INFO : VisionWorks on Host : Reading package lists...
14:50:37 INFO : VisionWorks on Host : Building dependency tree...
14:50:37 INFO : VisionWorks on Host : Reading state information...
14:50:37 ERROR : VisionWorks on Host : E: Version '1.6.0.500n*' for 'libvisionworks' was not found
14:50:37 INFO : VisionWorks on Host : E: Version '1.6.0.500n*' for 'libvisionworks-dev' was not found
14:50:37 INFO : VisionWorks on Host : E: Version '1.6.0.500n*' for 'libvisionworks-samples' was not found
14:50:37 INFO : VisionWorks on Host : [ Package Install Finished with Error ]
14:50:37 INFO : VisionWorks on Host : [ 12.00 KB used. Disk Avail: 12.55 GB ]
14:50:37 INFO : VisionWorks on Host : [ NV_VISIONWORKS_HOST_COMP Install took 25s ]
14:50:37 ERROR : VisionWorks on Host : [error]: Error when apt install failed; [exec_command]: sudo apt-get update; sleep 0.5; sudo apt-get -y install libvisionworks=1.6.0.500n* libvisionworks-dev=1.6.0.500n* libvisionworks-samples=1.6.0.500n* ; [error]: exit status 100; [deb_path]: /media/imperiumdrive/MyPassport/vortex/Downloads/libvisionworks-repo_1.6.0.500n_amd64.deb
14:50:37 ERROR : VisionWorks on Host : command terminated with error
14:50:37 ERROR : VisionWorks on Host : Install 'VisionWorks on Host' failure, command < using adapter to install NV_VISIONWORKS_HOST_COMP@host to /media/imperiumdrive/MyPassport/vortex/nvidia/nvidia_sdk/JetPack_4.3_Linux > terminated with error.
Any help to debug the issue is much appreciated.
