The SDK Manager goes blank after I login.
I did a little bit of googling and I found that disabling the usage of the GPU for Electron application is the solution.
But I get an error:
$ sdkmanager --disable-gpu
Error: unknown argument ‘–disable-gpu’
I saw this post from NVIDIA: https://devtalk.nvidia.com/default/topic/1052707/general/drive-development-platform-xavier-pegasus-sdk-manager-gui-doesn-t-show-up-in-host-linux-pc/post/5347633/#5347633
Where you have an example with --disable-gpu.
So I am confused on why it is not working for me.
So is there any other way of disabling the GPU usage for SDK Manager?
Here are some details of my OS:
Distributor ID: Debian
Description: Debian GNU/Linux bullseye/sid
Release: testing/unstable
Codename: n/a
I could always change the Linux distro if that helps.
Thanks in advance for your time and help on this issue.
