Hi all , I’m trying to flash the SD-Card using SDK manager getting the following issues I’m unable to flash it.
Attaching Export Logs for your reference.
Note: Have flashed the target and build customised kernel from the same Ubuntu Host PC.Have Already flashed the Sd-card using the same SDK - Manager and it was booting. SDKM_logs_JetPack_6.0_(rev._1)_Linux_for_Jetson_Orin_Nano_modules_2024-06-07_14-05-27.zip (230.2 KB)
Hi @DaveYYY I had taken this log while in force-recovery mode for flashing using Sdk manager.
Attaching the log for your reference. jetson_flash_log.txt (82.6 KB)
Attaching Error log too.
12:38:14 SUMMARY: CUDA on Host - host: Install completed successfully.
12:38:14 SUMMARY: CUDA Cross Compile Package on Host - host: Install completed successfully.
12:38:14 SUMMARY: NvSci - host: Install completed successfully.
12:38:14 SUMMARY: VPI on Host - host: Install completed successfully.
12:38:14 SUMMARY: Nsight Systems - host: Install completed successfully.
12:38:14 SUMMARY: Nsight Graphics - host: Install completed successfully.
12:38:14 SUMMARY: Nsight Perf SDK - host: Install completed successfully.
12:38:14 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
12:38:14 SUMMARY: File System and OS - target_image: Install completed successfully.
12:38:26 ERROR: Flash Jetson Linux - flash: [ 0.0690 ] ERROR: failed to read rcm_state
12:38:30 ERROR: Flash Jetson Linux - flash: [ 0.0177 ] ERROR: failed to read rcm_state
12:38:38 ERROR: Flash Jetson Linux - flash: 65097 blocks
12:38:38 ERROR: Flash Jetson Linux - flash: gzip: /home/silex/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
12:38:49 ERROR: Flash Jetson Linux - flash: 88462 blocks
12:38:51 ERROR: Flash Jetson Linux - flash: 20+0 records in
12:38:51 ERROR: Flash Jetson Linux - flash: 20+0 records out
12:38:51 ERROR: Flash Jetson Linux - flash: 20 bytes copied, 0.00048123 s, 41.6 kB/s
12:38:53 ERROR: Flash Jetson Linux - flash: 131072+0 records in
12:38:53 ERROR: Flash Jetson Linux - flash: 131072+0 records out
12:38:53 ERROR: Flash Jetson Linux - flash: 67108864 bytes (67 MB, 64 MiB) copied, 0.529842 s, 127 MB/s
12:38:59 ERROR: Flash Jetson Linux - flash: /home/silex/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
12:38:59 ERROR: Flash Jetson Linux - flash: /home/silex/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
12:39:00 ERROR: Flash Jetson Linux - flash: [ 0.7130 ] ERROR: value 0x31 is out of range
12:39:00 ERROR: Flash Jetson Linux - flash: [ 0.7137 ] ERROR: value 0x31 is out of range
12:39:00 ERROR: Flash Jetson Linux - flash: [ 0.7138 ] ERROR: value 0x31 is out of range
12:39:05 ERROR: Flash Jetson Linux - flash: [ 5.8835 ] ERROR: value 0x31 is out of range
12:39:05 ERROR: Flash Jetson Linux - flash: [ 5.8843 ] ERROR: value 0x31 is out of range
12:39:05 ERROR: Flash Jetson Linux - flash: [ 5.8844 ] ERROR: value 0x31 is out of range
12:39:05 ERROR: Flash Jetson Linux - flash: [ 5.8845 ] ERROR: value 0x31 is out of range
12:39:07 ERROR: Flash Jetson Linux - flash: [ 0.0177 ] ERROR: failed to read rcm_state
12:39:15 ERROR: Flash Jetson Linux - flash: 65097 blocks
12:39:15 ERROR: Flash Jetson Linux - flash: gzip: /home/silex/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
12:46:31 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 80000
12:48:02 ERROR: Flash Jetson Linux - flash: Write checkpoint 420000
12:48:08 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 430000
12:48:09 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 440000
12:48:11 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 450000
12:48:14 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 460000
12:48:31 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 520000
12:48:33 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 530000
12:48:34 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 540000
12:48:37 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 550000
12:48:42 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 560000
12:48:43 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 570000
12:48:45 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 580000
12:48:47 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 590000
12:48:49 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 600000
12:48:52 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 610000
12:48:53 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 620000
12:48:55 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 630000
12:48:57 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 640000
12:48:59 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 650000
12:49:00 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 660000
12:49:02 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 670000
12:49:04 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 680000
12:49:05 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 690000
12:49:12 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 700000
12:49:12 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 710000
12:49:13 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 720000
12:49:27 ERROR: Flash Jetson Linux - flash: [ 0.0521 ] ERROR: failed to read rcm_state
12:49:35 ERROR: Flash Jetson Linux - flash: 65097 blocks
12:49:35 ERROR: Flash Jetson Linux - flash: gzip: /home/silex/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
12:49:47 ERROR: Flash Jetson Linux - flash: 88462 blocks
12:49:48 ERROR: Flash Jetson Linux - flash: 20+0 records in
12:49:48 ERROR: Flash Jetson Linux - flash: 20+0 records out
12:49:48 ERROR: Flash Jetson Linux - flash: 20 bytes copied, 0.000104294 s, 192 kB/s
12:49:49 ERROR: Flash Jetson Linux - flash: 131072+0 records in
12:49:49 ERROR: Flash Jetson Linux - flash: 131072+0 records out
12:49:49 ERROR: Flash Jetson Linux - flash: 67108864 bytes (67 MB, 64 MiB) copied, 0.547218 s, 123 MB/s
12:49:55 ERROR: Flash Jetson Linux - flash: /home/silex/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
12:49:55 ERROR: Flash Jetson Linux - flash: /home/silex/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
12:49:56 ERROR: Flash Jetson Linux - flash: [ 0.7566 ] ERROR: value 0x31 is out of range
12:49:56 ERROR: Flash Jetson Linux - flash: [ 0.7573 ] ERROR: value 0x31 is out of range
12:49:56 ERROR: Flash Jetson Linux - flash: [ 0.7574 ] ERROR: value 0x31 is out of range
12:50:01 ERROR: Flash Jetson Linux - flash: [ 5.4478 ] ERROR: value 0x31 is out of range
12:50:01 ERROR: Flash Jetson Linux - flash: [ 5.4486 ] ERROR: value 0x31 is out of range
12:50:01 ERROR: Flash Jetson Linux - flash: [ 5.4487 ] ERROR: value 0x31 is out of range
12:50:05 ERROR: Flash Jetson Linux - flash: 88462 blocks
12:50:25 ERROR: Flash Jetson Linux - flash: 217039 blocks
12:51:20 ERROR: Flash Jetson Linux - flash: Error: The backup GPT table is corrupt, but the primary appears OK, so that will be used.
13:00:12 ERROR: Flash Jetson Linux - flash: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_JETSON_LINUX_COMP.silex.sh; [error]: 217039 blocks
13:00:13 ERROR: Flash Jetson Linux - flash: command terminated with error
13:00:13 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed.
modprobe: ERROR: could not insert 'spi_tegra210_quad': Exec format error
[ 8.897894] spi_tegra210_quad: disagrees about version of symbol module_layout
So apparently your kernel building process is problematic.
The SPI driver cannot be loaded so QSPI bootloader fails to get flashed.
It’s most likely you only build kernel image and in-tree modules, but not OOT modules, so the old OOT modules are imcompatible with your new kernel image.
I tried to boot the device after building the OOT modules with New kernel Image but the target is not booting up.
I ran this command to flash the target from the Host PC : sudo ./flash.sh jetson-orin-nano-devkit internal
But its taking longer than usual ??
040353] imx210! 0 0BN@`@b@``` failed
[ ��0p�����@mx20928x`n�����[ 0, "7 4��cbAndom�s���Y��0�� A@$.��$S 8800,227�ͥ�b@LDNH`obp@d`DpLA` address
[ 34.26�9] nvidia: disagrees about version of symbol fget
[ 34.269151] nvidia: Unknown symbol fget (err -22)
[ 34.269202] nvidia: disagrees about version of symbol fd_install
[ 34.269204] nvidia: Unknown symbol fd_install (err -22)
[ 34.269369] nvidia: disagrees about version of symbol wake_up_process
[ 34.269370] nvidia: Unknown symbol wake_up_process (err -22)
[ 34.269514] nvidia: disagrees about version�og�������iterate_fd
[ 34.2695�7]<nvidia: Unknown symbol iterate_fd�����-22)
[ 35.153310] Please complete system configuration setup on the serial port provided by Jetson's USB device mode connection. e.g. /dev/ttyACMx where x can 0, 1, 2 etc.
The situation is that you cannot use GUI to complete OEM config because display driver is dead.
You either use /dev/ttyACM0 as instructed by the log to do it, or skip it following the link I gave you.
But none of them is going to give you GUI unless you build the driver again correctly.
