SDK_Manager step 2 without disable host component
Hi
Due to some error
Is possible disable install host components on step 2?
I just want to reinstall my jetson nano 4G B01 in SD
or I can just run “dd” from Linux to flash SD.
Peter
Hi pantungmin,
Yes, you can unselect Host Machine on SDK Manager.
Please reference user guide: Install Jetson Software with SDK Manager — sdk-manager 2.0.0 documentation
For Jetson Nano platform, you can use SDK Manager or SDcard Image or dd command to flash image.
Please reference detail from: https://developer.nvidia.com/embedded/learn/get-started-jetson-nano-devkit#prepare
I will point out that many items can be unchecked, but it isn’t obvious that they can be unchecked. Host components are a simple uncheck. Even flash can be unchecked (for example, you could just install optional components to the Jetson).
