SDK Manager through os installation Orion NX 16GB (Ubuntu OS Installation Error on NVIDIA Orin NX with WD Blue SSD (500 GB) and NVMe Runtime)
I am facing an issue when attempting to install Ubuntu OS on my NVIDIA Orin NX system, which is equipped with a WD Blue SSD (500 GB) and utilizing the NVMe runtime for storage. Below are the specifics of the issue:
  • Model: NVIDIA Orin NX
  • OS Version: Ubuntu
  • Storage: WD Blue SSD (500 GB) with NVMe runtime
  • JetPack Version: 6.2
My WD Blue SSD is properly seated and recognized by BIOS as an NVMe drive.
While attempting to install Ubuntu OS, I encountered the following error:
Full File Log:
default_replay.txt (12.2 KB)
I would greatly appreciate assistance in resolving this issue. If there are specific drivers, firmware updates, or configurations needed for NVMe support or the WD Blue SSD, please let me know. Any known compatibility issues with NVMe storage on the Orin NX would also be helpful.
Thanks for visiting the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
Please click a EXPORT LOGS button and attach a zip file for us to review.
PFA…
For your review zip file is attached.
SDKM_logs_JetPack_6.2_Linux_for_Jetson_Orin_NX_16GB_2025-02-10_15-18-29.zip (197.9 KB)
Based on your log
Either the device cannot mount the NFS server on the host or a flash command has failed. Check your network setting (VPN, firewall,...)
Please disable the firewall and run the sdk manager again.
I am sill facing an issue when attempting to install Ubuntu OS on my NVIDIA Orin NX system
PFA…
SDKM_logs_JetPack_6.2_Linux_for_Jetson_Orin_NX_16GB_2025-02-28_11-48-24.zip (245.2 KB)
Please try below commands to disable the firewall and run sdk manager again.
sudo ufw disable
Already done.
here is new log file for your analysis. plz check and inform what is the issue in installation.
SDKM_logs_JetPack_6.1_(rev._1)_Linux_for_Jetson_Orin_NX_16GB_2025-03-05_15-21-13.zip (1.0 MB)
Some questions to confirm
  • Is your device a dev kit or a custom carrier board?
  • Is your host a native ubuntu or a virtual machine(e.g VMware…)
  • Is your NVMe formatted to ext4 before flashing?
carrier board
Leetop A606 carrier board for NVIDIA® Jetson Orin™ NX
Ubuntu 20.04.6 LTS
NVMe formatted
Hi
Our sdk manager not support the carrier board.
Please help reach out the vendor to get the customized bsp.
