SDK uefi boot disable
Continuing the discussion from How to disable network bootup scan from uefi on JetPack5.0.2:
Is there any way to disable in sdk
my Jetpack version is 5.1.1
how to disable the uefi network boot in sdk
also i need to modify "add new devices " to “BOTTOM”
If the device cannot be flashed/booted, please refer to the page to get uart log from the device:
Jetson/General debug - eLinux.org
And get logs of host PC and Jetson device for reference. If you are using custom board, you can compare uart log of developer kit and custom board to get more information.
Also please check FAQs:
Jetson AGX Orin FAQ
If possible, we would suggest follow quick start in developer guide to re-flash the system:
Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
And see if the issue still persists on a clean-flashed system.
